Linear Drag Force Homework: Acceleration & Constant Speed Calculations
The discussion centers on calculating the acceleration of a ball with a density of 1450 kg/m^3 submerged in a liquid with a density of 1400 kg/m^3, yielding an acceleration of 0.338 m/s^2 using the formula a=(g*(ρb-ρl))/ρb. Participants seek assistance in determining the constant sinking speed of the ball, assuming linear drag force. The relevant equations for viscous drag, particularly Stokes' Law, are suggested as a potential solution. There is a clear need for clarification on how to apply these equations to find the constant speed. Understanding the drag force in relation to the ball's motion in the fluid is essential for completing the homework.
antoman
We sink ball with density 1450 kg/m^3 in some liquid with density 1400 kg/m^3
a) What's acceleration in moment we drop the ball?
b) With what constant speed will the ball sink in balace? Assuming that the drag force is linear. Radius of ball is 3mm and viscosity of liquid is 200 Pa s.
a=(g*(ρb-ρl))/ρb
a... acceleration
ρb=1450 kg/m^3
ρl=1400 kg/m^3
g=9,81 m/s^2
a) That's easy, using the formula and you get a=0,338 m/s^2
b) Need help here, no idea how to solve
a=(g*(ρb-ρl))/ρb
a... acceleration
ρb=1450 kg/m^3
ρl=1400 kg/m^3
g=9,81 m/s^2
Have you learned the equation for calculating the viscous drag force (in creeping flow) on a sphere of diameter, when the sphere is moving with a velocity v relative to the viscous fluid?
If you mean in colledge probably yes, but me personaly don't know that equation.
Google Stokes Law.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
