Linear Expansion of Steel Girder Due to Temperature Change
The discussion revolves around calculating the height a steel girder rises due to a temperature increase of 32° C, given its length of 3.77 m and a linear expansion coefficient of 12*10^-6 /C. Initial calculations suggested a height rise of 1.79 m, which was deemed unlikely. A revised calculation showed a rise of approximately 0.052 m, which the poster found surprising yet correct. There was debate about the applicability of the Pythagorean theorem in this context, with differing opinions on its validity for small differences. The conversation highlights the complexities of thermal expansion calculations in fixed structures.
chawki
A girder made of steel. The length of the girder is 3.77 m. In the middle of the girder there is a fracture. The temperature rises 32° C.
Find the height that the girder rises from the middle, if it is fixed at both ends. The linear expansion coefficient for steel is 12*10^-6 /C.
Is it 1.79m?
chawki said:
Is it 1.79m?
Seems a bit unlikely. Show your work.
L-L0 = 1.2 E-5 * 3.77 * 32 = 0.00144m
L=3.77+0.00144 = 3.77144
3.77144/2= 1.88572
3.77/2= 1.885
1.885722 =x2 + 1.8852
x=0.052m ?
That looks better!
Wow, my answer is correct?!
You sound surprised.:smile:
yes iam. i lost some self-confidence
I think it doesn't look correct...because the the difference between L and L0 is tooooo small to allow the use Pythagorean theorem, don't you think ?
I don't know of any reason why Pythagoras would fail to work no matter how small the difference was; a triangle is still a triangle if it has three sides!
