Calculate Temperature for Closed Expansion Joint on Steel Bridge
In summary, the question is asking at what temperature a 215 m steel bridge with an expansion joint of 18.0 cm at one end and a temperature of -15.0 degrees C will close the joint. Using the equation Change in L=L(alpha)T, the temperature change needed for the bridge to expand 18 cm and reach a length of 215.18 m is found to be 54.8 degrees C, assuming a thermal expansion coefficient of 12*10^-6.
lilkrazyrae
64
A 215.m steel bridge has an expansion joint of 18.0cm at one end at -15.0 degrees C. At what temperature would the joint be closed?
I would use the equation Change in L=L(alpha)T
But would the L equal zero since the joint is closed?
Yes sorry I forgot the m. So are there two answers? And the bridge would have to move from 18cm to 215m for the second part that seems improbable.
No, the bridge has length of 215 m when its temperature is -15°C.
If the temperature of the bridge increases, the length will increase (thermal expansion).
One is asked to find the temperature at which the bridge will expand 18 cm to close the gap, in which case the bridge length will be 215.18 cm.
The thermal strain is the ratio of length after expansion to the length before expansion, i.e. 215.18/215 = 1 + [itex]\epsilon[/itex], where [itex]\epsilon[/itex] is the thermal strain.
Look at the link I provided - http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/thexp.html#c2
Let L = 215 m and [itex]\Delta{L}[/itex] = 0.18 m (or 18 cm), and then find the temperature difference [itex]\Delta{T}[/itex] assuming you know the thermal expansion coefficient [itex]\alpha[/itex].
See also the plate below - http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/thexp.html#c3
ok so .18=(215m)(12*10^-6)(T(f)-(-15)) and 69.767=T(f) +15 Finally T(f)=54.8 degrees C. Is this correct??
Correct. :smile:
What is a closed expansion joint on a steel bridge?
A closed expansion joint on a steel bridge is a structural element that allows for thermal expansion and contraction of the bridge without causing damage. It is typically a closed metal box that is attached to the ends of adjacent bridge sections and allows for movement in all directions.
Why is it important to calculate the temperature for a closed expansion joint on a steel bridge?
Calculating the temperature for a closed expansion joint on a steel bridge is important because it ensures that the joint can accommodate the thermal movements of the bridge. If the temperature is not properly calculated, it can lead to premature failure or damage of the joint.
How is the temperature for a closed expansion joint on a steel bridge calculated?
The temperature for a closed expansion joint on a steel bridge is typically calculated using a combination of factors such as the coefficient of thermal expansion of the bridge material, the length of the bridge section, and the expected temperature changes in the area. This calculation can be done using specialized software or by hand using mathematical equations.
What are some common challenges in calculating the temperature for a closed expansion joint on a steel bridge?
Some common challenges in calculating the temperature for a closed expansion joint on a steel bridge include variations in temperature across different sections of the bridge, changes in the surrounding environment, and the effects of external factors such as wind and sunlight. It is important to consider all of these factors when performing the calculation.
Can the temperature for a closed expansion joint on a steel bridge change over time?
Yes, the temperature for a closed expansion joint on a steel bridge can change over time due to various factors such as weather, structural changes to the bridge, and the aging of materials. It is important to regularly monitor and recalculate the temperature to ensure the joint is functioning properly.
