Loads on automobile door frames
  • Thread starter Thread starter aniruddha
    Automobile Frames
Automobile door frames experience various loads beyond just the hinge load, including dynamic loads from opening and closing, impact loads during collisions, and static loads from the vehicle's weight. These loads contribute to the overall strength and rigidity of the vehicle's body, making doors a critical component for structural integrity. The design and materials used in door frames are essential for ensuring passenger safety during crashes. Proper engineering can enhance the door's ability to withstand these loads, ultimately affecting the vehicle's performance and safety ratings. Understanding these factors is vital for automotive design and safety standards.
aniruddha
What are the kind of loads that act on an automobile door frame while opening, closing other than the load on the hinge?
i can not say for sure but the doors in todays production automobile are a very critical component to the strength and rigidity of the entire body. Key to survival during a crash.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
