Looking for help with a statics problem
  • Thread starter Thread starter MobiusMind
    Statics
The discussion centers on solving a statics problem involving a long cylinder resting on compression springs, with the cylinder's center of gravity slightly off-center, causing it to tilt. The user seeks to determine the angle of tilt and the deflection of the springs under equilibrium conditions. Responses suggest using a diagram to define unknowns and applying statics principles to calculate forces and angles. Formulas for maximum spring deflection and cylinder rotation angle are provided, which account for the number of springs and their spring constants. The conversation emphasizes the importance of correctly computing moments and forces to achieve accurate results.
MobiusMind
So, I've been trying to figure this problem out for a good part of the day. If anyone could help me out or give me some guidance I would really appreciate it. I basically have a long cylinder sitting on some compression springs. The bottom of the cylinder is hollowed out and the springs are equally spaced along the bottom edge of the cylinder, say one spring every 10 degrees, and the springs are identical with the same spring constant. The center of gravity of the cylinder is located high on the cylinder and a little bit off of the centerline. Not enough that the cylinder will topple over, but just enough that the cylinder will sit at an angle. So what I am looking for is how to figure out what that angle will be and what the deflection in the springs will be, assuming everything is in equilibrium and there are no oscillations. It seems like it should be a simple statics problem, but I must be missing something. thanks
Calculate the moment of inertia of the springs around the cylinder base, then apply the cylinder force and moment due to gravity to the spring pattern. For 36 springs around the cylinder base, I currently got maximum spring deflection, delta = -0.02778*m*g*(4*b/d + 1)/k, and cylinder rotation angle, alpha = asin[0.2222*m*g*b/(k*d^2)], where m = cylinder and contents total mass (located at center of gravity, CG), g = 9.8067 m/s^2, d = cylinder diameter, b = horizontal distance between cylinder axial centerline and mass CG, and k = spring constant for each spring.
Thanks nvn, I will try to duplicate your equations. Just curious, how would that scale if I were to use 200 springs instead of 36?
Welcome to PF!
Hi MobiusMind ! Welcome to PF! :smile:
Yes, it's a simple statics problem (so moment of inertia shouldn't come into it).
Hint: in problems ike this, draw a diagram, and give letters to all the unknowns.
In this case, the two unknowns are the angle of tilt (call it θ), and the compressed length of the lowest spring (or the highest, or the middle ones, whichever you chose, call it x).
Then you know the lengths of all the other springs, in terms of θ and x, so you can calculate their compression forces.
Then put those forces in the diagram, together with the weight, and use the usual statics rules to find θ. :smile:
MobiusMind: For 200 springs, I currently got maximum spring deflection, delta = -m*g*(4*b/d + 1)/(n*k), and cylinder rotation angle, alpha = asin[8*m*g*b/(n*k*d^2)], where n = total number of equally-spaced springs, and all other parameters are as defined in my first post.
MobiusMind: To be more general, maximum spring deflection is delta = -(4*P*b + 4*F*z + P*d)/(n*k*d), and cylinder rotation angle is alpha = asin[8*(P*b + F*z)/(n*k*d^2)], where P = resultant of all vertical applied loads (including cylinder and contents weight), F = resultant of all horizontal applied loads (if any), b = horizontal distance between cylinder axial centerline and load P, z = vertical distance between cylinder base and load F, d = cylinder diameter, n = total number of equally-spaced springs, and k = spring constant for each spring.
The above formulas assume moment F*z is in the same direction as moment P*b. If, instead, moment F*z can only be applied in the opposite direction of moment P*b, then input a negative value for F, in both of the above formulas.
Parameter b is obtained by computing the moment (about a horizontal axis at the cylinder base passing through the cylinder axial centerline) of all vertical applied loads (including the cylinder and contents weight), then dividing this moment by P. Likewise, z is obtained by computing the moment (about the same axis used for computing b) of all horizontal applied loads, then dividing this moment by F.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
