Lorentz transformations - relative speeds of frames
Suzanne observes two light pulses emitted 3μs apart, while Mark sees them 9μs apart, indicating Mark is moving relative to Suzanne. Using the Lorentz transformations, it was determined that Mark's speed relative to Suzanne is approximately 0.943c. The separation in space of the pulses as observed by Mark can be calculated using the formula d = vt, yielding about 2.5km, assuming no additional distortions from light travel time. The discussion also highlighted the ambiguity in the problem regarding whether it involves the Doppler effect, which could complicate the interpretation of the time intervals. Overall, understanding the context of the observers' positions is crucial for accurate calculations.
ElijahRockers
Suzanne observes 2 light pulses to be emitted from the same location, but separated in time by 3μs. Mark sees the emission of the same two pulses separated in time by by 9μs.
a) How fast is Mark moving relative to Suzanne?
b) According to Mark, what is the separation in space of the two pulses?
Time dilation, Lorentz transforms
Part A
My first attempt had Mark as the 'primed' observer, since I am used to that frame moving, and they are asking about Mark's relative velocity to Suzanne, and I got an answer that didn't make any sense for v.
I realized that since Mark is observing a larger time interval than Suzy, she must be in the 'primed' frame for Δt = γΔt' to make any sense. So I did it that way, and found a v of .943c which I think is correct. (The answers to this question are not in the back of the book)
But as for the question 'How fast is Mark moving relative to Suzanne' I am not sure. Is the answer to this question -.943c, since Suzy's frame is moving away from Mark in the positive direction?
Part B
Suzy observes the pulses to be emitted from the same location, so Δx' = 0. Mark's observation however, Δx, is going to be non-zero, since the pulses are moving in his frame.
So in this case, would I just use (vt = d) .943c * 9μs ≈ 2.5km ? or is there something about the speed of light and the pulses moving away from him that would distort this answer? Or should I just assume he observes the pulses instantaneously? If the latter, then would 2.5km be the correct answer?
Thanks for the help in advance..
ElijahRockers said:
Part A
When using the full Lorentz transformations, the prime and unprimed designations are arbitrary.
When you use the special case formula for time dilation, Δt = γΔt', then you have to make sure that the primed frame is the one in which the events take place at the same location. (Like the ticks of a clock.)
You weren't given any information about direction, so just give the magnitude of the speed.
Part B
Yes, that's all there is to it. You can also use the full Lorentz transformations. That would a good exercise for you.
Ok... I couldn't use the special time dilation formula for Mark because his events didn't occur at the same location in his frame.
So when you say the full Lorentz Transformations, are you meaning
x' = γ(x - vt)
y' = y
z' = z
t' = γ(t- vx/c2)
Where the primed frame is moving along the positive x-axis with respect to the unprimed frame? If so, what is the main difference between these and their 'inverse' transformations:
x = γ(x' + vt')
t = γ(t' + vx'/c2)
Is this still describing a situation where the primed frame is moving along the positive x-axis with respect to the unprimed frame?
If so, then I think it's all starting to come together... thanks again for your help.
The problem statement seems to imply that the source is at rest in Suzanne's frame of reference. There is no doppler correction for her frame, but there will be a doppler correction for Mark's frame, and it will depend on whether Mark is moving toward Suzanne's source or away from Suzanne's source.
Right.
x' = γ(x - vt)
y' = y
z' = z
t' = γ(t- vx/c2)
I mean those and the inverse transforms.
Definitely.
x = γ(x' + vt')
t = γ(t' + vx'/c2)
Events happen for everyone. The 'regular' LT let's you transform measurements from the unprimed frame to the primed frame; the 'inverse' LT does the reverse. They are both saying the same thing.
Good point. The problem is ambiguous in its language where it says: "Mark sees the emission of the same two pulses separated in time by by 9μs."
It's not clear whether it's just sloppy language or if they really did mean the problem to be about the Doppler effect.
@ElijahRockers: Can you tell from context? Have you covered the Doppler effect yet?
The point is this: The Lorentz Transforms relate measurements made in the various frames after light travel time has been accounted for. So they don't necessarily describe what an observer literally sees--that depends on how close they are to the light source and how long it takes for the light to travel to their eyes.
If you've covered the Doppler effect for light, then you'll need to rework the problem. Try it.
Mark's velocity relative to Suzanne also depends on whether Suzanne is located between the source and Mark, whether the source is located between Suzanne and Mark, or whether Mark is located between Suzanne and the source.
It's worse than that. Even if Suzanne is collocated with the source, what Mark sees will depend on how the source is moving with respect to him: Whether directly toward or away from him or transverse to him.
So I seriously doubt this was meant to be a Doppler problem.
It's too late in the evening for this, lol
