Lost with Probability homework
The discussion focuses on a probability homework problem involving a student who knows 40 out of 60 questions and needs to determine the probability of knowing all three selected questions, exactly two, and at least two. The initial calculations for part (a) are confirmed as correct, but the approach for part (b) is incorrect as it fails to account for selecting one wrong answer alongside two correct ones. Additionally, part (c) is flawed because it assumes a constant probability of 2/3 for each selection, ignoring the reduced pool of questions after each choice. The correct method for part (c) involves using the results from parts (a) and (b) to derive the answer. Overall, the student needs to adjust their calculations for parts (b) and (c) to arrive at accurate probabilities.
battery2004
A student has learned answers to 40 questions out of 60. A student has to pick 3 questions. What is the probability, that the student will know:
a) all 3 questions
b) exactly 2 questions
c) at least 2 questions
a)
So all the possible cases would be - C^{3}_{60}
The favorable cases would be - C^{3}_{40}
So the answer is C^{3}_{40} / C^{3}_{60}
b)
Same as a) but the favorable cases are C^{2}_{40}
c)
So the probability for one question to be right would be 40/60 = 2/3.
Probability that all the questions are right (2/3)^3
Probability that 2 of the questions are right and one is wrong (2/3)^3 * (1/3)
so
(2/3)^3 + 2*((2/3)^2*(1/3)) = 16/27
Can someone confirm these answers?
Thanks in advance.
Your answer to (a) is correct, but your answers to (b) and (c) aren't.
For (b), you calculated the number of ways you can choose two correct answers, but you actually want the number of ways to choose two correct answers and one wrong answer.
For (c), you can't assume the probability remains at 2/3 for each pick. Once the student has answered a question, he or she has a smaller pool of questions to choose from. In other words, there's no replacement after each trial.
The idea behind part (c) is that you can find its answer in terms of the answers to (a) and (b).
Thanks for you answer.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
