What is the Magnetic Field and Flux at Point O?
The discussion centers on calculating the magnetic field and flux at point O due to a straight wire and a circular wire. The magnetic field (B) at point O is derived from both the straight wire and the circular wire, with the straight wire's field opposing the circular wire's field. The participants clarify that the induced current in the circular wire is not relevant since the magnetic field is not changing; instead, they need to determine the current required in the circular wire to cancel the field from the straight wire. The calculations for the magnetic field and the necessary current in the circular wire lead to a conclusion that the circular wire must carry a current of 1.25 A if it consists of two loops. The conversation highlights the distinction between magnetic flux and magnetic flux density, emphasizing their different units and roles in the context of the problem.
Helly123
[/B]
There is lead XY shaped as straight wire. Next to it, circular lead with radius 0.10 m.
They are in the same plane.
XY to center of circle, O is 0.20 m.
Curent flowing through XY is 15.7 A
1) find magnetic field (B) at O[/B]
B induced by XY at O ##u_0##I/2##\pi##r
B induced by Circle at O ##u_0##I/2R
So i just add both?
Since B induced at O by XY is opposed direction, the current at Circular wire is opposed direction to current XY?
2) flux at O
flux = BA cos ##\theta##
So A is 1? Because it just a point at O?
While, B equal to B at number 1) ?
3) when B at O set to 0 by a current passing in circular lead. Find magnitude and direction of this current
B at O is zero
This current does it refer to current at circular wire?
Could you please restate the problem exactly as given? Looks to me that you have current going through the straight wire and a circular area defined. Are you supposed to find the flux through that area?
This is it. Hope it shows clear
It only says that, flux at O.
OK, much clearer. For parts 1 & 2 you only need consider the magnetic field generated by the straight wire.
For 1) the formula before is correct?
For 2) i simply count Area as 1?
Ah, it looks like they are distinguishing B (magnetic flux density) from H (magnetic field strength). For this problem, they are simply related. See: Magnetic Field
(I'm too used to calling B the magnetic field strength, as done in most elementary books.)
Likes Helly123
For number 1) i have to find H = 1.25 A/m
For number 2) i have to find B = 1.57 10^-6 Wb/m^2
As for number 3.
1.25 A/m
How many meter to be counted for that circular wire? How to tell that the induced current have opposite direction to current XY?
You need to know how to find the field at the center of a current loop.
You'd use a version of the right-hand rule. For example, a clockwise current in that circular loop would produce a field (at the center) going into the page.
You know the direction of the field from the straight wire (from another version of the right-hand rule) so the field from the current loop must oppose that direction to cancel it.
Likes Helly123
Doc Al said:
You need to know how to find the field at the center of a current loop.You'd use a version of the right-hand rule. For example, a clockwise current in that circular loop would produce a field (at the center) going into the page.
Ok.
The induced current always opposed to the original?
Btw. When i calculated H
the formula is H = B/##u_o## - M
What is M? M for the lead?
There's no induced current here. (The magnetic field is not changing.) There is the field from the straight wire and the field from the circular loop. They must oppose each other since you are asked for the current in the loop that gives zero net field in the center.
Helly123 said:
Ok.
I'm assuming this is a loop of wire with nothing inside it. So all you need is H = B/##u_o##.
Doc Al said:
There's no induced current here. (The magnetic field is not changing.) There is the field from the straight wire and the field from the circular loop. They must oppose each other since you are asked for the current in the loop that gives zero net field in the center.I'm assuming this is a loop of wire with nothing inside it. So all you need is H = B/##u_o##.
Do you have article about loop wire next to straight wire?
How come there is magnetic field from loop if there is no current induced in it?
Helly123 said:
View attachment 224974 [/B]
So i just add both?
2) flux at O
B at O is zero
I have a doubt, is there any difference between magnetic flux and magnetic flux density?
There is a current in the loop, but not an induced current. You need to figure how much current the loop must have to cancel the field from the straight wire.
(Induced current is created by a changing magnetic field -- not relevant here.)
Since the magnetic field H at O is 1.25 A/m
Distance from loop to O is 0.1 m. So current is 12.5 A? Where the current comes from if not induced?
I think the wikipedia said so
Here's how you find the field from a loop of current-carrying wire: Field at Center of Current Loop
It is added externally. (That loop of wire may be part of a circuit.)
Yeah you are right, even though I read it from there could not grasp more idea about that, some please help me with this,
is there difference in their units
Or what makes them different from each other?
The wikipedia explained it too
H units is A/m
B units is Wb/m2
Field from straight wire XY is 1.57 10^-5 Wb/m2
B at loop = ##u_o## I/2R
1.57 10^-5 Wb/m2 =( 4##\pi## 10^-7 • I ) / 2(0.1)
I = 2.5 A
It is still wrong btw..
When I solve for B from the straight wire, I get B = 10-6 T
Is the straight line wire infinitely long?
That's what I assume.
How come? ##u_0## I / 2##\pi##r
Oops, my bad. I agree with your result of 1.57 10-5.
I = 2.5 A
My calculations agree with yours.
One thing that could explain the discrepancy: They refer to the loop as "doubly-rolled". Does that mean it's really two loops? (Which would make the required current half as much.)
Likes Helly123
Yes. I think so. So it makes the current flow is 1.25 A for each loop?
Right. (It's one current going through both turns of wire.)
Awesome. Thanks @Doc Al
