Srun
- 1
A copper wire with cross-sectional area S=2.5 mm^2 is bent to make three sides of a square frame that can pivot about the axis 00' as shown below. The wire is located in a uniform vertical magnetic field B. If upon passing a current I=16 milliAmperes through the wire, the wire deflects by an angle Θ= 0 degrees, find value of B (in SI units).
F = Force, measured in Newtons
I = current in wire, measured in amperes
B = magnetic field vector, measured in teslas
= vector cross product
L = a vector, whose magnitude is the length of wire (measured in metres), and whose direction is along the wire, aligned with the direction of conventional current flow.
I can't seem to find what r and the unit vector for r is.
Any hints? Or am I looking at this in the wrong way?
