Magnetic flux in a straight wire to a cylinder
To determine the total magnetic flux through a cylinder surrounding a straight wire carrying a current of 3.00 A, the magnetic field must first be calculated using the formula B = (μ₀I)/(2πr). The area of the cylinder is essential for calculating the flux, which is given by the equation flux = BAcosθ. The angle θ is zero since the magnetic field lines are perpendicular to the surface of the cylinder. The discussion emphasizes the need to find the magnetic field before proceeding with the flux calculation.
goWlfpack
A long, straight wire carrying a current of 3.00 A is placed along the axis of a cylinder of radius 0.500 m and a length of 5.00 m. Determine the total magnetic flux through the cylinder.
flux=BAcostheta
i found the area of the cylinder first and i don't have any idea where to go from there. I am not really finding any helpful equations...
Obviously, you have to calculate the magnetic field due to the current.
would i use B= (Moconstant)I/2pir??
Yep.
