Magnetic force on sides of square solenoid
The discussion centers on calculating the magnetic force on a square solenoid with 5 turns, carrying a current of 2 A in a uniform magnetic field of 0.07 T. The force on sides ab and cd is determined to be 0.0021 N, with ab directed in the +k direction and cd in the -k direction, while sides bc and da experience no force. The torque on the coil is evaluated using the relation τ = μ x B, where μ represents the magnetic moment of the coil. The participant initially questioned whether to consider the force from the solenoid's own magnetic field in addition to the external field but later resolved the issue independently.
  • Understanding of magnetic forces on current-carrying conductors
  • Familiarity with the right-hand rule for determining force direction
  • Knowledge of torque calculations in physics
  • Basic concepts of magnetic moments and their significance in electromagnetism
  • Study the derivation of the magnetic moment μ for different coil configurations
  • Learn about the application of the right-hand rule in various electromagnetic contexts
  • Explore the relationship between torque and magnetic fields in solenoids
  • Investigate the effects of varying current and magnetic field strength on force calculations
Students and educators in physics, particularly those focusing on electromagnetism, as well as engineers working with electromagnetic devices and applications.
physicsnublet
A square 5-turn coil with sides .03 m long and carrying 2 A of current is placed in a uniform magnetic field of .07 T, as shown.
What is the magnitude and direction of the force on each of the four sides?
What is the magnitude and direction of the torque [tex]\tau[/tex] on the coil about its center, if any? Use the fact from mechanics that [tex]\tau[/tex] = r x F due to a force F applied with lever arm r.
What is the magnetic moment [tex]\mu[/tex] of this coil? What is the torque on the coil evaluated using the relation [tex]\tau[/tex] = [tex]\mu[/tex] x B?
Force on a current-carrying wire
F=I[tex]\hat{l}[/tex]x[tex]\vec{B}[/tex]
Field of ideal solenoid
B=[tex]\mu[/tex][tex]_{0}[/tex]NI[tex]\overline{l}[/tex]
I wasn't sure how to translate F=I[tex]\hat{l}[/tex]x[tex]\vec{B}[/tex] into a coil with 5 loops, so I just multiplied IN[tex]\hat{l}[/tex]x[tex]\vec{B}[/tex]=(2A)(5 loops)(.03m)(.07T)=.0021 N for sides ab and cd. By right hand rule, I said ab is in the +[tex]\hat{k}[/tex] direction and cd is in the -[tex]\hat{k}[/tex] direction. I said bc and da were parallel to B so there was no force on them.
My biggest question: When you calculate force of a coil in a uniform magnetic field, do you have to take into account the force that comes from the current itself?
The uniform magnetic field seems to be from an external source, so to find total force do I also have to use the solenoid to find field and force from that, then add that force to the uniform field's force?
Thanks very much for any help; I'm rather stumped by all this.
Nevermind, I figured it out.
  • · Replies 25 ·
