Magnetism and Electric Potential Problem
An electron accelerated through a 1.6 kV potential difference enters a gap between parallel plates with a 120 V potential difference and a 20 mm separation. The user calculated the electron's velocity as 2.37e7 m/s using kinetic and potential energy equations. They derived the magnetic field strength needed for the electron to travel straight through the plates as 2.53e-4 T but received an incorrect response on their assignment. A response pointed out that while the value for B may be correct, the direction of the magnetic field must be considered, following the right-hand rule. The user remains uncertain about the correct approach to the problem.
bbbbbev
Hi. I'm having some trouble with this problem:
An electron accelerated from rest through potential difference 1.6 kV enters the gap between two parallel plates having separation 20.0 mm and potential difference 120 V. The lower plate is at the lower potential. Neglect fringing and assume that the electron's velocity vector is perpendicular to the electric field vector between the plates. What uniform magnetic field allows the electron to travel in a straight line in the gap?
I was thinking that all I really needed to do was figure out the velocity of the electron and plug all the values into the equation
F = qvBsin(phi)
phi = 90 degrees in this problem, so the equation can just be written as
F = qvB
To find v, I used the fact that change in kinetic energy = change in potential energy.
KE = PE
(1/2)mv^2 = q(deltaV)
v = sqrt((2q(deltaV))/m)
After plugging in all the numbers I got:
v = sqrt(2(1.6e-19C)(1600V)/(9.11e-31kg))
v = 2.37e7 m/s
When I plug that into the magnetic field equation I get:
B = F/qv, so B = Eq/qv. Since E = V/d and the q's cancel, I then used
B = V/(distance)(v)
B = (120 V)/(0.02 m)(2.37e7m/s) = 2.53e-4 T
But that was not the correct answer. I know this is a lot of work to look through, but I'd appreciate any help anyone could give me because I'm really not sure I'm looking at this problem correctly. What am I missing.
Thanks,
Beverly
you got the value of B correct, but you must be careful about hte direction of the magnetic field. Since the magenetic field obeys the right hand rule which way should hte magnetic field point?
I think the magnetic field is in the k direction, which is to the left, but I don't think that value for B is right. I put that in as my answer (on webassign), and it counted it wrong. I don't know what else to try! Thanks for you help! Beverly
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
