Magnitude and Direction of Force
To determine the direction and magnitude of force F3, given that the resultant force of three vectors is 20 lb and F3 is the smallest force, the discussion highlights the challenge of having multiple unknowns in the equations. The participants emphasize the need to consider both F3 and the angle θ as unknowns, complicating the calculations due to the presence of sine and cosine functions. A suggestion is made to square and add the forces to simplify the problem. The conversation reflects a struggle with the mathematical approach but encourages collaboration for a solution. Ultimately, the focus remains on resolving the equations to find F3 and its direction.
chadovP
http://img243.imageshack.us/my.php?image=61581222vi0.jpg
http://xs433.xs.to/xs433/08440/untitled601.jpg
I need to find the direction and the magnitude of F3 given only the figure and the resultant force of the 3 vectors =20 lb, plus F3 being the smallest force between all of them.
Tried Rx and Ry and squaring them but I have 3 unknows in 1 solution...
any ideas?
Welcome to PF!
Hi chadovP! Welcome to PF! :smile:
(have a theta: θ :wink:)
I don't get it :confused:
the only two unknowns are F3 and θ …
what unknowns did you have? :smile:
yes but there are sin θ and cos θ which makes the equation very complicated.
ah!
but that's still only one unknown!
Hint: square, and add. :wink:
2 unknows mate! F3 and the angle...
so i have f3 sqaured and the angle in one equation and that the part i am not getting...
square, and add! :rolleyes:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
