Magnitude of a component of a triple star
The apparent total magnitude of a triple star system is given as 0.0, with two components having apparent magnitudes of 1.0 and 2.0. The discussion revolves around calculating the apparent magnitude of the third component using the relationship between flux densities and magnitudes. By summing the individual flux densities of the components, the apparent magnitude of the third component is derived to be approximately 0.9. The calculations confirm that the relationship between the individual flux densities and the total flux density leads to the correct answer. The final result aligns with the expected outcome of the problem.
TheSodesa
The apparent total magnitude of a triple star is ##m_0 = 0,0##. The apparent magnitudes of two of its components are ##m_1 = 1,0## and ##m_2 = 2,0##.
What is the apparent magnitude of the third component?
Answer: 0,9
Since according to Norman Pogson (1856), the ratio of two subsequent classes of brightnesses (flux densities)
\begin{equation}
\frac{F_m}{F_{m+1}} = 100^{1/5} = 10^{2/5} = 10^{0,4},
\end{equation}
the difference between two apparent magnitudes:
\begin{equation}
m_x - m_y = -\frac{5}{2}\lg{ \left( \frac{F_x}{F_y} \right)}
\end{equation}
If the magnitude ##0## is chosen to represent a certain flux density ##F_0##, generally corresponding to the flux density ##F## there is a corresponding magnitude
\begin{equation}
m = -\frac{5}{2}\lg{ \left( \frac{F}{F_0} \right)}
\end{equation}
From the assignment, the total magnitude of the system is chosen to be zero. Therefore we can get the apparent magnitude of the third component from ##(3)## as follows:
\begin{equation}
m_3 = -\frac{5}{2}\lg{ \left( \frac{F_3}{F_0} \right)},
\end{equation}
where ##F_0## is the flux density of the system.
Since I have no idea, what the flux densities are, I think I might be better off trying to solve for the ratio ##\frac{F_3}{F_0}##. Now
\begin{equation}
\frac{F_3}{F_1} = 10^{-0,4(m_3 - m_1)} \text{ and } \frac{F_3}{F_2} = 10^{-0,4(m_3 - m_2)}
\end{equation}
Solving these for ##F_3##:
\begin{equation}
F_3 = 10^{-0,4(m_3 - m_1)}F_1 = 10^{-0,4(m_3 - m_2)}F_2
\end{equation}
Plugging into ##(4)##:
\begin{equation}
m_3 = -\frac{5}{2}\lg{ \left( 10^{-0,4(m_3 - m_1)}\frac{F_1}{F_0} \right)},
\end{equation}
Now
\begin{equation}
\frac{F_1}{F_0} = 10^{-0,4m_1},
\end{equation}
which when plugged into ##(7)## yields ##m_3 = m_3##, so I am obviously missing something.
But what exactly?
Leaving magnitudes aside for the moment, what do you think the relatioship would be between the individual flux densities and the combined flux density?
Likes TheSodesa
Well, picking up my second edition of Understanding Physics by Mansfield and O'Sullivan, flux density is defined as follows: F:= \lim_{\Delta A \rightarrow 0} \frac{\Delta \Phi}{\Delta A}\hat{t}, where ##\Phi## is the flux through area ##A## on the enclosing surface, and ##\hat{t}## a unit vector pointing in the direction of the flux. If we have 3 sources producing flux inside of a surface, at each point on the surface their flux should be summed, meaning the total flux density
\begin{equation}
F_{tot} = \lim_{\Delta A \rightarrow 0} \frac{\sum_{i=1}^{n}\Delta \Phi_i \hat{t_i}}{\Delta A} = \sum_{i=1}^{n}F_i,
\end{equation}
where ##n## is the number of elements producing flux. At least that's what my intuition says.
If my assumption in post #3 is correct, the total flux detected at the observation point ##F_0 = F_1 + F_2 + F_3 \iff F_3 = F_0 - (F_1 + F_2)##. Then ##(4)## becomes
\begin{equation}
m_3 = -\frac{5}{2}\lg \left( \frac{F_3}{F_0} \right) = -\frac{5}{2}\lg \left( 1 - \frac{F_1 + F_2}{F_0} \right) =
-\frac{5}{2}\lg \left( 1 - \frac{F_1}{F_0} - \frac{F_2}{F_0} \right)
\end{equation}
Again, we can solve for the ratios ##\frac{F_1}{F_0}## and ##\frac{F_2}{F_0}## as follows using ##(3)##:
\begin{equation}
\frac{F_1}{F_0} = 10^{-0,4m_1} \text{ and } \frac{F_2}{F_0} = 10^{-0,4m_2}
\end{equation}
Therefore
<br /> m_3 = -\frac{5}{2}\lg \left( 1 - \frac{F_1}{F_0} - \frac{F_2}{F_0} \right) = -\frac{5}{2}\lg \left( 1 - 10^{-0,4m_1} - 10^{-0,4m_2} \right) = 0,883002 \approx 0,9,<br />
which was the desired answer.
Thanks. :smile:
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
