How Do You Calculate the Acceleration of an Electron in Motion?
To calculate the acceleration of an electron starting from rest and moving with constant acceleration, the relevant equation is X = Xi + 1/2at^2. Given that the electron travels 4.7 cm in 8.2 ms, the initial velocity (Vi) is zero, allowing the equation to simplify. The initial position (Xi) can be chosen as zero, making the calculation straightforward. After solving, the acceleration is determined to be 1.398 km/s². This method effectively demonstrates how to derive acceleration from distance and time in motion problems.
delfam
electron starting from rest and moving with constant acceleration travels 4.7cm in 8.2ms. What is the magnitude of this acceleration? Answer in km/s^2
X=Xi + (Vi)t + 1/2at^2
Vi = 0 so the equation becomes X = Xi + 1/2at^2
t = 8.2ms and X = 4.7 so 4.7 = Xi + 1/2a(8.2)^2
I feel like I did everything right up to this point but all I need is acceleration to plug in but I'm not sure how to get that.
You do not need to plug in acceleration. You are trying to solve for a.
Thus, what you need to plug in is xi, the starting position of the particle.
4.7cm = .000007km and 8.2ms = .0082 seconds
electron is from rest so Vi=0 so the equation is 2(X-Xi)/t^2, I have time and I have X which equals .000047km. How to I find Xi, or is that also zero?
Hello!
problem statement says that: "starting from rest", which means that initial velocity is zero. For initial position Xi you can chose whichever value you like. What is given - the distance moved, that is X-Xi. You can chose X = 4.7 cm only if your Xi = 0.
thanks guys, yeah I got it, it was 1.398 km/s^2
your welcome
