What is the Effect of Electrical Charges on the Attraction Between Two Humans?
The discussion centers on calculating the electrical attraction between two humans after transferring a specific number of electrons. The initial charge for each person is determined based on the number of electrons per kilogram and their mass. The formula used for calculating the force is F=kQ1Q2/r^2, where Q1 and Q2 represent the adjusted charges after electron transfer. Additionally, the conversation touches on the presence of other charged particles in human tissue and their potential influence on the overall electrical force. The final goal is to determine the magnitude of the attraction, rounded to the nearest Newton.
EliteCodexer
Human tissue contains about 3*10^27 electrons per kg of material. Suppose two humans are located 1370 km apart and each has a mass of 60 kg. We now transfer 5*10^21 electrons from one person to the other. What will be the magnitude of the resulting attraction, rounded to the nearest Newton?
I used the equation F=kQ1Q2/r^2
except I am not sure if I used the right charges.
for Q1, i found it by ((3*10^27)(6)-(5*10^21))(1.6*10^-19)
and Q2: ((3*10^27)(6)+(5*10^21))(1.6*10^-19)
If those electrons had not been transferred from one person to another, what would have been the electrical force between the two people? Put another way, in addition to those 1027 electrons per kg, what other charged particles are present, and what is their effect?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
