Magnitude of average force exerted by each particle on other
The problem involves two particles, one with a mass of 5.0 kg and an initial velocity, and another with a mass of 6.0 kg that is initially at rest. After an interaction, the first particle moves at a reduced speed and angle, and the task is to determine the average force exerted by each particle on the other during the interaction, which lasts 0.2 seconds.
  • Exploratory, Assumption checking
  • Participants discuss the change in momentum and its implications for calculating the average force. There is uncertainty about whether to average the masses and velocities of both particles. Some participants suggest focusing on the change in momentum of the first particle.
The discussion is ongoing, with participants providing tips and prompting each other to clarify the definition of change in momentum. There is no explicit consensus yet, but guidance has been offered regarding the relevance of the equations provided.
Participants are navigating the constraints of the problem, including the interaction time and the initial conditions of the particles. There is a focus on understanding the implications of the change in momentum without resolving the calculations.
TRVSA
A particle of mass 5.0kg travels initially with a velocity of 8.0m/sˆı and then interacts with a particle of mass 6.0kg which was initially at rest. After the interaction the 5.0kg mass travels at a speed of 4.0m along a direction which makes an angle of 53◦ with the x-axis as illustrated.
  1. If the interaction took 0.2s, what was the magnitude of the average force exerted by each particle on the other?
F = I/Δ t
I = ΔP
I found the angle between x-axis and second particles velocity (30 degrees) and the speed of the second particle after interaction (5.4m/s). And now I am unsure whether to take the average of the masses and velocities of both particles or what
F = I/Δ t
I = ΔP
Take a tip from the relevant equations you posted. What is ΔP here?
Another tip: You can answer the question without knowing anything about the second particle.
change in momentum?
TRVSA said:
change in momentum?
Yes, that is what it means, but what is its value in this question?
  • · Replies 23 ·
  • · Replies 16 ·
11K
