Magnitude of electric field at a point problem
In summary, the conversation discusses a problem where the magnitude of the electric field at point P is to be determined using Coulomb's Law. The attempt at a solution involves calculating the individual electric fields of different charges and then combining them to get the total electric field. However, there is an error in the calculation of the angle, resulting in an incorrect answer.
roam
1,271
If Q = 80 nC, a = 3.0 m, and b = 4.0 m in the figure, what is the magnitude of the electric field at point P?
[PLAIN]http://img19.imageshack.us/img19/1596/picat.jpg
[tex]\vec{E} = k_e \frac{|q|}{r^2}[/tex]
[tex]\left\{\begin{matrix}\vec{E}_x=k_e \frac{|q|}{a^2+b^2} \cos \ \phi
\\ \vec{E}_y=k_e \frac{|q|}{a^2+b^2} \sin \ \phi\end{matrix}\right.[/tex]
ke = 8.9 x 109 (Coulomb's constant)
The charge -Q only has an x component, the electric field due to this charge is:
[tex]\vec{E}_{(-Q),x}= (8.9 \times 10^9) \times \frac{-80 \times 10^{-9}}{4^2}=-44.5[/tex]
The two "2Q" charges cancel out each other's y-components, so we need to only consider their x components:
[tex]\vec{E}_{(2Q), x} = (8.9 \times 10^{9}) \times \frac{2 \times (80 \times 10^{-9})}{3^2+4^2} \cos 45 = 40.27[/tex]
I got the 45 degree angle is from here:
[PLAIN]http://img200.imageshack.us/img200/5499/pic2ae.jpg
So the total electric field is:
[tex]\vec{E}_{(-Q), x}+2\vec{E}_{(2Q), x}=-44.5+ 2\times(40.27)=36.05 N/C[/tex]
But this is wrong since the correct answer must be 47 N/C. What's wrong with my calculation? Any help is greatly appreciated.
why 45°?
ehild
check angle again ...
tan 45 = 1
is a=b? no
do it again
Thank you very much guys, I got it. :smile:
Your calculation is incorrect because you have not taken into account the distance between the charges and point P. The correct formula for the electric field at point P is:
\vec{E} = k_e \frac{|q|}{r^2} \hat{r}
Where r is the distance between the charge and point P, and \hat{r} is the unit vector in the direction from the charge to point P. In this case, you need to calculate the distance between each charge and point P separately, and then calculate the electric field due to each charge using the formula above. Finally, you can add the electric fields due to each charge using vector addition to get the total electric field at point P.
In addition, your calculation for the electric field due to the -Q charge is incorrect. The correct formula is:
\vec{E}_{(-Q)} = k_e \frac{|q|}{r^2} \hat{r}
Where r is the distance between the -Q charge and point P, and \hat{r} is the unit vector in the direction from the -Q charge to point P. In this case, the distance r is not equal to 4m, as you have assumed. You need to use the Pythagorean theorem to calculate the distance r.
1. What is the formula for calculating the magnitude of electric field at a point?
The magnitude of electric field at a point is calculated using the formula E = kQ/r^2, where E is the electric field, k is the Coulomb's constant, Q is the charge, and r is the distance from the point to the source of the electric field.
2. How do you determine the direction of the electric field at a point?
The direction of the electric field at a point is determined by the direction of the force that a positive test charge would experience if placed at that point. The direction of the field is always away from positive charges and towards negative charges.
3. Can the magnitude of electric field at a point be negative?
Yes, the magnitude of electric field at a point can be negative. This indicates that the direction of the electric field is opposite to the direction of the force that a positive test charge would experience at that point.
4. What factors affect the magnitude of electric field at a point?
The magnitude of electric field at a point is affected by the magnitude of the charge creating the field, the distance from the point to the source of the electric field, and the medium in which the field exists. It is also affected by any other charges or objects in the vicinity.
5. How is the magnitude of electric field at a point related to the potential at that point?
The magnitude of electric field at a point is related to the potential at that point through the equation E = -∇V, where E is the electric field, ∇ is the gradient operator, and V is the electric potential. This means that the electric field is in the direction of decreasing potential.
