Magnitude of electric field with square loop
The discussion focuses on calculating the electric field generated by a square loop of charged wires. The loop consists of four identical wires, each with a linear charge density, and the goal is to find the electric field at a specific distance above the center of the loop. The equation provided simplifies the calculation, but there is uncertainty about the accuracy of the initial result obtained. Participants suggest using symmetry and trigonometry to combine the electric fields from each wire segment. Clarifications on variable definitions and comparisons with previous problems are also discussed to ensure understanding of the situation.
py208
The square loop shown below is made up of four identical wires of length scripted l = 18 cm each charged with a linear density λ = 18 nC/m.
Find the magnitude of the electric field at a distance z = scripted l/2 above the center of the loop.
Start by first simplifying the result from problem 21-46,
E = (2kλ)(L/x)(4x2 + L^2)^-1/2
where x = (z^2 + (L/2)^2)^1/2. Then make use of the symmetry of the situation.
I used this equation to solve and got 335.53967, But I don't know what to do after this, or if this number is even right. Help please!
Perhaps you want to show a bit more. Not numbers, but what variables stand for. I suppose (what else can I do) that 21-46 asks for the electric field on the Perpendicular Bisector of a charged rod ? this link, example 2.3 works that out very nicely.
Does that check with your 21-46 result ?
It looks to me as if your z is his (/her) y
I think I see a difference, so I might misinterpret the situatiuon.
Anyway, it simplifies a lot if z = L/2.
The next step is to add the four ##\vec E## with simple trigoniometry.
