Magnitude of the average force of air resistance on a rocket
The discussion revolves around calculating the average force of air resistance on a toy rocket during its ascent. The engine provides an upward force of 9.00N, and the rocket, with a mass of 54.0g, rises to a height of 339 meters. The work done by the engine is calculated as 225J, while the potential energy at the peak is determined to be 17.94J. Participants suggest using the Work-Energy equation to account for the work done by air resistance and the changes in kinetic energy. Clarifications on mass conversion and calculations are provided to assist in solving the problem.
IAmPat
An engine supplies an upward force of 9.00N to an initially stationary toy rocket, of mass 54.0g, for a distance of 25.0m. The rocket rises to a height of 339 meters before falling back to the ground. What was the magnitude of the average force of air resistance on the rocket during the upward trip?
2. The attempt at a solution
Fa = Applied Force = 9N
Work done by Engine: F * Change in Y = 9 N * 25m = 225J
PEf = Final Potential Energy
PEf = mgh = (.0054)(9.8)(339)
PEf = 17.94 J
-PEf is also the work done by gravity
I'm actually really confused as to how to go about this problem. Never had to do one like this really. If someone could give me a starting point, I'll try to work out more from there.
First correct the mass of the rocket to read 0.054 kg. With that change, your calcs for the work done by the engine and gravity are correct.
Now what about the work done by the air and the initial and final kinetic energies?. Enter that into the Work-Energy equation, you know, the one that says the total work done by all forces acting on the object is equal to the change in the kinetic energy of the object?
