Magnitude of the Initial Velocity
The discussion focuses on calculating the time a tennis ball is in the air and determining its initial velocity after rolling off a flat roof 65 meters high. The time calculated for the ball's descent is 3.64 seconds. To find the magnitude of the initial velocity, the horizontal distance of 418 meters is divided by the time in the air, yielding the horizontal component of velocity. The initial velocity is then derived as the vector sum of the horizontal and vertical components, assuming air resistance is negligible.
  • Understanding of basic physics concepts, particularly projectile motion.
  • Knowledge of vector addition in two dimensions.
  • Familiarity with kinematic equations for vertical and horizontal motion.
  • Ability to perform calculations involving time, distance, and velocity.
  • Study the kinematic equations for projectile motion in detail.
  • Learn about vector decomposition and how to calculate vector sums.
  • Explore the effects of air resistance on projectile motion.
  • Practice similar problems involving different heights and distances to solidify understanding.
Students studying physics, educators teaching projectile motion, and anyone interested in understanding the principles of motion and velocity calculations.
Rose1996
A flat roof has a height of 65m above the ground. A tennis ball rolls off the edge of the roof and hits the ground at a point 418m horizontally from the edge of the roof.
A.) How much time is the ball in the air?
B.) What is the magnitude of the initial velocity?[/B]2. The attempt at a solution
I'm fairly positive that the answer to A is 3.64 seconds, but I'm having trouble understanding how to get the magnitude of the initial velocity and what it is exactly.
The velocity has horizontal and vertical components. Assuming we are to ignore air resistance (the problem doesn't say, but that is usually assumed in these simple problems, where not stated otherwise), the horizontal component won't change while the vertical component will.
So if you have the time the ball is in the air and the horizontal distance traveled you can get the horizontal velocity by a simple division. The initial velocity will be the vector sum of that plus the initial vertical velocity.
Okay, I think I get it now. Thank you so much!
  • · Replies 21 ·
  • · Replies 31 ·
  • · Replies 38 ·
