Manipulating Simple Harmonic Motion Equation
When both the amplitude and period of an object in simple harmonic motion are doubled, the maximum speed remains unchanged. The maximum velocity is determined by the equation v_max = A_0 * ω, where A_0 is the amplitude and ω is the angular frequency. Doubling the amplitude increases A_0, while doubling the period decreases ω, resulting in a net effect that keeps v_max constant. The sine function's maximum value of 1 simplifies the analysis, confirming that the maximum speed does not change. Therefore, the answer to the homework question is that the maximum speed remains unchanged.
Glorzifen
An object moves with simple harmonic motion. If the amplitude and the period are both doubled, the object's maximum speed is:
A) Quartered
B) Halved
C) Quadrupled
D) Doubled
E) Unchanged
x(t) = Acos(wt + \varphi)
v(t) = -wAsin(wt + \varphi)
Since 2 double the period (T) is to halve the frequency (f) because of (f = 1/T), and since omega (w) = 2\pif...then w will be halved as well (right?):
f = 1/2T --> .5f --> 2\pi.5f = .5w
So that gives me: v(t) = -.5wAsin(.5w + \varphi)
And with the amplitude doubled: v(t) = -wAsin(.5w + \varphi)
Not sure if I did any of that correctly and I'm not sure what that means for my speed...is it halved? Any help would be appreciated. Thanks.
You are correct in your logic that \omega is halved as well. Let's look at what the question is asking. What is the *Maxiumum* velocity? You have written the equation for velocity:
v(t) = A_0 \omega Sin(\omega t)
You should know that A_0 is the maximum amplitude.
Because the maximum value of any Sin function is 1, that means that the maximum velocity will be given by
v_{max} (t) = A_0 \omega
Now what will happen when the amplitude and period are both doubled?
Ah. Okay...I didn't know how to deal with the whole sine thing (obviously). So based on this Vmax equation the max velocity will remain unchanged. Correct?
Exactly. When dealing with maximum values, your sin and cosine functions will generally disappear for the reasons stated above.
