Calculating Mass of Subsample of Tobacco & Barium Hydroxide
  • Thread starter Thread starter waqaszeb
    Mass
The discussion revolves around calculating the mass of tobacco in a 25 mL aliquot from a solution created by mixing 2.0830 grams of tobacco and 1 gram of barium hydroxide in a chloroform:toluene mixture. The initial assumption was to use a straightforward proportion (2.0830 x (25ml/100 mL)) to find the mass in the aliquot. However, it was pointed out that this method is incorrect because the addition of barium hydroxide increases the total volume of the solution, resulting in a final volume that exceeds 100 mL. Consequently, the mass of tobacco in the 25 mL sample cannot be accurately calculated without knowing the final volume of the solution. To obtain a precise measurement, the solution must be adjusted to exactly 100 mL with solvent.
waqaszeb
Hello,
If I get 2.0830 grams of tobacco and add 1 gram of barium hyrdoxide to it. Mix it in 100 mL of chloroform:toluene mixture, I essential have a 100 mL solution right? Now I take a 25 mL aliquote from that? what will be the mass in grams of tobaco in that 25 mL sample?
I thought simply 2.0830 x (25ml/100 mL) would do but my T.A. asked me to recalculate that because I did it wrong.
Thanks.
Chemistry news on Phys.org
If you add these things to 100 mL of the solvent, you would have slightly more than 100 mL, so taking 25 mL would yield sample that is below 1/4 of the total. To be sure you can do it this way you would have to fill up to 100 mL with solvent.
I don't see a way to correctly estimate the sample mass with the data given, as the final volume is not known and impossible to calculate.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
