Mastering physics problem regarding speed and tension
The discussion focuses on determining the speed at which the tension is equal in both wires attached to a 2.0 kg sphere revolving in a horizontal circle. Participants suggest analyzing the vertical forces acting on the sphere in relation to the tension components and applying equations for horizontal forces based on angular velocity and radius. The conversation emphasizes finding the lengths of the wires to calculate the radius needed for the equations. Ultimately, the solution involves substituting values to derive the angular velocity. The user successfully finds the answer with the help of hints provided.
hieule
Two wires are tied to the 2.0 kg sphere shown in the figure View Figure . The sphere revolves in a horizontal circle at constant speed.
For what speed is the tension the same in both wires?
What is the tension?
I reallllly need some hints to figure the first part, and the second part...thank you
Find the vertical force on the sphere in terms of the vertical components of the tension (1).
Then write the equation (2) for the horizontal force on the sphere (in terms of \omega and r
Then find the lengths of the wires in order to find r.
Substitute r into (2) (both tensions = T) and use T from (1) to find \omega
AM
yeah, got the answer, thanks
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
