Math olympiad products question
The discussion revolves around solving a Math Olympiad problem that requires finding the smallest integer n such that the product 5(32 + 22)(34 + 24)(38 + 28)...(32n + 22n) exceeds 9256. Participants explore various approaches, including the use of the AM-GM inequality and logarithmic properties to establish bounds for n. A key point of contention is whether the correct answer is 8 or 9, with calculations suggesting that n must be at least 9 to satisfy the inequality. The conversation emphasizes the importance of accurately accounting for all terms in the product and understanding how to derive a closed form for the expression. Ultimately, the consensus leans towards n being 9, as lower bounds established by the methods discussed indicate that 8 would not suffice.
timetraveller123
ok here is another problem that wrecked me in todays olympiad
find smallest integer n such that
5 (32 + 22)(34 + 24)(38 + 28)...(32n + 22n) > 9256
ok once again how am i supposed to start
does writing 3 = 2+1 help?
i don't see how i can factorize or cancel terms can't telescope cause not summation
hint please!
Could that last factor be $$( 3^{2^n}+2^{2^n} ) \quad\rm ? $$
In which case we have to decide between n=8 or n=9
The first three factors certainly suggest that.(Actually, the first 4 factors do.)
hint please![/B]
Use AM-GM and properties of Logarithms.
Likes timetraveller123
vishnu 73 said:
cant telescope cause not summation
The powers of 2 are swiftly dwarfed by the powers of 3, so you can get a lower bound on the LHS by ignoring the powers of 2. You can improve it a bit by multiplying by 13/9 so as to bring back in the 22 term, etc.
You mean 8 or something less, right?
Wolfram alpha says the answer is 9.
Ah, yes. I counted the 5 factor twice. Thanks.
ok does it go something like this
@haruspex
the sum ignoring 2k terms for now can be written as
5 ( 32)(34) ... ( 32n)
5 ( 91)(92) ... (92(n-1)) > 928
5( 920+21 + ... 2n-1)
5( 9 2n-1 )
then
5/9 (92n) > 928
now for the correction factor how is it 13/9 where did you get that from
@Buffu
by am gm do you mean i apply it terms like
32 + 22 ≥ 2 (3) (2)
or do you mean like taking the whole left hand side as the product and ending up with
LHS ≤ (5 + 32 + 22 ... 32n + 22n)n+1/(n+1) n+1
or none of theses please help
@haruspex
5( 9 2n-1 )
then
5/9 (92n) > 928
@Buffu
32 + 22 ≥ 2 (3) (2)
Yes I mean term wise,
##\displaystyle \prod_{n= 0}^k (2^{2^n} + 3^{2^n}) \ge \prod_{n=0}^k 2 \sqrt{6^{2^n}}##
Can you find a closed form for the second product ?
Not quite. The LHS is a lower bound for the expression you started with, so it is not necessarily greater than 9256. But if you find an n that satisfies this inequality (9 is obviously the lowest) then that is an upper bound for the answer to the question.
Having found the answer is 9 or less, the question is whether it might be 8, say.
In throwing away the 22n terms, the first discarded one turned 32+22=13 into 9. Multiplying by 13/9 merely restores that. Note that this is more significant than the discarding of 2 term in the next bracket, and so on. So my thinking was to see whether restoring them successively from the left would push the n=8 product over 9256.
However, it is quite likely that Buffu's method is more effective at that. On the other hand, this is still only a lower bound for the expression. If the more accurate approximation still does not get you over 9256 with n=8 then you are no further forward. You need an upper bound on the LHS if we are to rule out n=8 as being too low.
Likes Buffu and timetraveller123
sorry for the late reply currently in overseas
@Buffu
22n + 32n ≥ 2 * 62n-1
so the product on the left hand side can be simplified after extracting the first term as the first term is 2 * √6
the product on the left hand side is equivalent to
≥2k * 62K+1-1 * √6
is this correct? how to proceed?
@haruspex
now i see where you got the 13/9
but the given answer was actually 8 by a local source
Doh!
The left hand side reduces to a remarkably simple closed form.
Imagine expanding the product. You will get a sum of terms like 2a3b.
What are the possible values of a? What is the relationship between a and b?
@haruspex
oh wow it does it is sort of like a binomial expansion in the sense that powers add up to a constant depending on the highest power in the product except that you don't have binomial coefficients and the powers in subsequent terms decrease by 2 instead of 1
so a + b always add up to 2n+1-2 where n is the highest power in the product
correct?
≥2k * 62K+1-1 * √6
I get the answer as ##\displaystyle \prod^k_{n = 0} 3^{2^n} + 2^{2^n} \ge 2^k \times 6^{2^k - 2^{-1}} > 3^{512}##
Taking log base 6,
##k \log_6 2 + 2^k - 1/2 > 512\log_6 3 \iff k \log_6 2 + 2^k > 512\log_6 3 + 1/2##
You can solve this and get ##k = 9##.
@Buffu but once again as @haruspex said when we take the am gm we only get a lower bound
for example we can 4 ≥ 2 but that does not mean 4 is bigger than 3 only if 2 is bigger than 3 it is the same logic the right hand side of the am- gm can be lesser than 3512 while the lhs still being greater than 3512 i.e. lhs of am-gm ≥ 3512≥ rhs of am-gm
i think this is what @haruspex was trying to drive at
Likes Buffu
Well, you get a lower bound for the product, which leads to an upper bound for n. I.e. you can show n is at most 9. But the cruder approach I started with, omitting the powers of 2, leads to that also. We need the collapse to the closed form to show n cannot be 8.
why not 8 because after all we only considered the correction factor for the first term
and i am sorry i meant you get a upper bound with am gm
What do you get for the closed form expression?
If you write the factor 5 at the front as 2+3 you should get a+b=2n+1-1.
oh you i forgot about 5 now i am getting that but how does the closed form help
I ask again, do you have the closed form? It shows immediately that 8 is not enough.
wait what do you mean by closed form
i am getting the products multiplied out as
22n+1-1 + 22n+1-332 ...32n+1-322+ 32n+1-1
is this what you mean by closed form
First, the sum is not quite right. I think you are leaving out the 2+3 term again. The exponents should be all values from 0 to 2n+1-1.
Secondly, it is not closed form. Closed form should contain no integrals, limits or variable-length sums.
You need to perform the summation. It's not hard.
sorry i did it wrong
so starting over
\begin{equation}
\prod_{i=0}^{n}{2^{2^i} + 3^{2^i}} = \sum_{i=0}^{2^{n+1} -1}{2^i 3^{2^{n+1} -1 -i}} \\
\end{equation}
is this summation correct ?
if yes how to solve the summation?
Likes Buffu
What is the ratio between successive terms?
\frac {2}{3}?\\
or\\
\frac {3}{2}
depending on which way you go ?
vishnu 73 said:
\frac {2}{3}?\\
or\\
\frac {3}{2}
How do you sum a series with a fixed ratio between terms?
so the sum can be written as
\sum_{i=0}^{2^{n+1} -1}{ ({\frac{2}{3}})^i 3^{2^{n+1} -1}}
a geometric series
so the formula for finite terms is
3^{2^{n+1}}(1- ({\frac{2}{3}})^n)
is this correct?
so it can't be 8 because then it becomes 9256 * k
where k is less than 1 more than 0 correct?
vishnu 73 said:
so the formula for finite terms is ##3^{2^{n+1}}(1- ({\frac{2}{3}})^n)##
I think it should be ##3^{2^{n+1}}-2^{2^{n+1}}##. Check it for small n.
vishnu 73 said:
so it can't be 8 because then it becomes < 9256
Right.
haruspex said:
I think it should be 32n+1−22n+132n+1−22n+13^{2^{n+1}}-2^{2^{n+1}}. Check it for small n.
i am not sure here is my working
formula for geometric series:
\frac{a(1 - r^n)}{1-r}\\
r = \frac{2}{3}\\
a = 3^{2^{n+1} -1 }\\
3^{2^{n+1} -1 }\frac {1-(\frac{2}{3})^n}{1 - \frac{2}{3}}\\
3^{2^{n+1} -1 }\frac {1-(\frac{2}{3})^n}{\frac{1}{3}}\\
3*3^{2^{n+1} -1 }(1-(\frac{2}{3})^n)\\
3^{2^{n+1} }(1-(\frac{2}{3})^n)\\
i don't see where's my mistake
That n is not the same as the n in the problem.
  • #31
oh you careless me but i am still getting a different result this is my working
3^{2^{n+1}} ( 1- (\frac{2}{3})^{2^{n+1} -1 }) \\
3^{2^{n+1}} - 3( 2^{2^{n+1} -1 })
now what am i doing wrong
  • #32
You are not applying the upper bound correctly in the sum. If the sum is up to the term rk then the numerator should have 1-rk+1. You omitted the +1.
  • #33
oh wait the index starts at i=0 not 1 so it must be 22n+1 correct ?
then it is equal to
3^{2^{n+1}} - 2^{2^{n+1}}
  • #34
then it is equal to
Yes.
14K
14K
22K
12K
