What is the Wronskian of the given solution vectors?
B18
We know that X= (1 over 3)e^t+(4 over -4) te^t is a solution to X'=(2 1 over -1 0)X.
Verify that the solution vectors are linearly independent on (-∞,∞).
I know that the wronskian of the solution vectors cannot be 0 if they are linearly independent.
So I found X1=(1 over 3) e^t and X2= (4 over -4)te^t
when i did the wronskian i did..
l e^t 4te^t l
l 3e^t -4te^t l
I got -16te^(2t). this would be 0 at t=0. Am i missing something? i figured that it should be independent because it says to verify that it is... are these linearly dependent?
thanks to anyone for the help!
l e^t 4te^t l
l 3e^t -4te^t l
If the wronskian is nonzero ANYWHERE then the functions are linearly independent. If they are dependent it will vanish everywhere.
Okay, so if the wronskian is equal to 0 and only 0 then the solutions are linearly dependent. However if the wronskian is anything other than 0 they are linearly independent!
Yes, they are linearly independent.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
