Max Height Calculation for a Spring-Loaded Pinball on a Tilted Surface
  • Thread starter Thread starter Nm
    Spring
To calculate the maximum height a spring-loaded pinball reaches on a tilted surface, energy conservation principles are applied, equating the potential energy of the spring to gravitational potential energy. The formula used is 0.5k*x^2 = mgh, where h represents the vertical height gained. It is crucial to consider the angle of the tilt, as it affects the height calculation. Additionally, when determining the pinball's speed at a given height, the relationship between elastic potential energy, kinetic energy, and gravitational potential energy must be established. The discussion also highlights the importance of considering rotational kinetic energy if the pinball's radius is taken into account.
Nm
Let's say I have a pinball (solid sphere) with a given mass and radius, and it is held back at a certain distance from equilibrium on a spring. The spring constant k is given, and the ball is then fired onto the pinball machine surface, which is tilted. How would I find the maximum height the pinball rolls to (above its initial location.)? I know I should use energy conservation, but is this the correct formula: 0.5m(vi^2) + 0.5k(yi^2) = 0.5m(vf^2) + 0.5k(yf^2)? Would yf be the same as the height at which the pinball machine is tilted or is it the distance from the spring equilibrium the pinball travels to? Thanks.
The potential energy stored in the spring as the ball is pushed and held back is then converted into kinetic energy as the ball is moving up the machine, then into gravitational potential energy as it moves up the surface.
The potential energy os a spring is,
PE_s = 1/2 k*x^2
The gravitational potential energy is,
PE_g = mgh
so if you set these equal to each other,
1/2*k*x^2 = mgh
now solve for the height h (or y, whatever you want to call it)
Thanks for your help. I have another question: When the pinball is at a certain distance above its initial location (on the way up), how would I find its speed? Do I set KE = PE of the spring?
in this case,
elastic potential energy of the spring = kinetic energy of the ball + its gravitational potential energy.
assumptions we have to made in order to use the law of conservation of energy:
1. the surface of the machine has no friction.
2.only elastic potential energy, kinetic energy and potential energy are involved. no sound energy is produced.
what i know is that the h in the formula mgh refers to the vertical distance or height. so i think it is important to know the angle the machine is tilted.
Leong said:
in this case,
Another thing you assume by saying that the,
"elastic potential energy of the spring = kinetic energy of the ball + its gravitational potential energy." is that the ball is not spinning and/or it is a point mass.
I only bring this up because in the original statement of the problem, Nm said that the ball had a given radius (amongst other things). This almost seems to imply that we are suppose to take the rotation of the ball into account. If this is indeed the case, then not only does the ball have gravitational potential energy, and [normal] translational kinetic energy, but also rotational kinetic energy (the "spin" energy if you will).
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
