Max height of thrown object with 12m/s at 1/5 of height
An object is shot vertically upward with a speed of 12 m/s when it reaches one fifth of its maximum height. The discussion revolves around determining the initial speed of the object and its maximum height, using kinematic equations related to free-falling objects.
  • Mixed
  • Participants discuss the application of the kinematic equation vf^2 = vi^2 - 2g(yf - yi) and the implications of obtaining negative values in calculations. There is an exploration of the definitions of height and the interpretation of fractions in the context of the problem.
The discussion includes attempts to clarify the correct application of kinematic equations and the interpretation of height in the problem. Some participants question the assumptions made regarding the height and speed at different points in the object's trajectory, while others provide insights into the correct usage of the equations.
There is a noted confusion regarding the interpretation of 1/5 as a fraction of maximum height rather than a specific height measurement. Participants are navigating through the implications of this misunderstanding in their calculations.
brundlfly
An object is shot vertically upward and has a speed of 12 m/s when it reaches one fifth of its maximum height.
a. What is the initial speed of the object?
b. What is the maximum height of the object?
Free falling objects
I used the formula vf^2 = vi^2 - 2g(yf - yi) and got 144 = 0 + 19.6(1/5 - 0), I solved for 1/5 so I have 144/19.6 = 1/5 and got 1/5 = 7.35 meters. This times 5 yields 36.73 meters. This would be it for part b. But I am stuck on part a where I have to find the speed. Any advise on how to approach this? Thank you.
You got a negative value (because -2g(yf - yi) is negative), and then you probably thought "oops, the square of velocity can't be negative, so let's change the sign and hope for the best". It does not work that way.
You should have asked yourself "why did I get a negative value where only a positive one is possible? Where did I go wrong"?
Not really, the reason why I ended up with a positive value instead of a negative is because
144 = 0 - 2(-9.6)(1/5 height) = 144 = 0 -(-19.6)(1/5 height) = 144 = 19.6 (1/5 height). If you don't agree let me know.
The basic kinematic equation is ##v_f^2 = v_i^2 + 2 a(s_f - s_i) ##. Adapted to free fall, it is either ## v_f^2 = v_i^2 + 2g (y_f - y_i) ##, where ## g ## is then taken negative, or ## v_f^2 = v_i^2 - 2g (y_f - y_i) ##, where ## g ## is then taken positive. But you cannot have both the equation in the form ## v_f^2 = v_i^2 - 2g (y_f - y_i) ## and ## g ## negative in it.
yf is not 1/5.
When the speed is zero, the object has reached the maximum height. (h_max).
When the speed is 12 m/s the object height is 1/5 from this maximum height.
1/5 is not a height in meters (or other unit of length) but a fraction.
Saying that 1/5=7.35 m is nonsense.
