What is the Maximum Angular Velocity of a Reverse Three-Speed Transmission?
The discussion focuses on calculating the maximum angular velocity of a reverse three-speed automotive transmission. Key calculations include determining the number of teeth on various gears, the angular velocity of the drive shaft, and the torque on the output shaft. The user seeks assistance in calculating how many turns the load shaft makes to reach its maximum angular velocity, initially unsure of the approach. After working through the physics and equations, the user arrives at a total of 1344 revolutions, while another participant suggests the answer should be 667 revolutions, prompting a reevaluation of the calculations. Ultimately, the user resolves their confusion and confirms their understanding of the problem.
orangeincup
I calculated a, b, and c, I just need help with d.
1. Homework Statement [/b]
The operation of a "reverse" three-speed automotive transmission is illustrated the in
figure. Each of the gears rotate about a fixed axis. Note that gears A and B, C and D, E
and F are in mesh. The radii of each of these gears are shown in the figure. The shaft G
starts from rest and reaches its maximum angular velocity of ωG = 60 rad/s. The mass
moment of inertia of the load shaft is given as 5.0 kgm^2
. The shaft G is driven by a 2 hp motor. Assume that the efficiency of the gear box is 80 %.
a) If gear A has 45 teeth and if B, C and D, E have the same diametral pitch
calculate the number of teeth in gears B, C, D, E, F.
b) Determine the angular velocity of the drive shaft H.
c) Calculate the torque on the output shaft.
d) How many turns does the load shaft make to reach its maximum angular velocity.
P=ω*τ
τ=IgAc
a) Used the ratios to solve, all end up having to be .5, so 45, 15, 15, 25, 35, 30
b) Multiplied ω*45/15, and repeated for every gear until I reduced it to 127ω
c)(127/.8) for efficiency, converted 2hp into 1491.5 W. 1491.5/(127/.8)=9.4
d) Not sure where to start for this... I assume I need something that has rpm in it, and I have to use the moment of inertia somehow.
(d) that would be correct - though it will help to think through the physics before looking for an equation.
What determines the mag angular velocity?
What is the initial angular velocity?
Does it have a uniform acceleration?
Likes 1 person
The rpm from the motor?
127ω? Or is that the max? I don't know how the acceleration of this system works
I think it is constant, but I don't know what it is
T=IgAc
9.4 N-m=5kg*m^2 * Ac
Ac=1.88
Solving for time: ω=ω0+Act
(126rad/s)/(1.88)=t
t=67.02s
126 rad/s * 60 / 2*∏ = 1203 rpm
1203 rpm *(67.02s/60)=1344 revolutions
Does this look correct?
orangeincup said:
T=IgAc
Ac=1.88
(126rad/s)/(1.88)=t
t=67.02s
That looks likt the sort of reasoning I'd use yeah.
I knew you'd get there :)
Likes 1 person
According to my solution the answer is 667 rev, should I be using the 60 rad/s anywhere? Or is there any mistake you see?
Of course... That's the max speed.
I didn't go through your work in detail. Where did you get the figure you used?
Never mind
Never mind I figured it out.
