Maximum Kinetic Energy of a Particle with Force F = F0e^(–kx)?
  • Thread starter Thread starter kiowaviator
    Energy
The discussion revolves around calculating the maximum kinetic energy of a particle subjected to a force defined by F = F0e^(–kx). The participant successfully applies the Work-Kinetic Energy theorem, recognizing that the work done (W) equals the change in kinetic energy (Kf - Ki), with the particle starting from rest at x = 0. They derive the work done by integrating the force over the distance, ultimately simplifying to W = F0(1/k). The conclusion is reached by multiplying F0 with 1/k, confirming the maximum kinetic energy expression. The participant expresses gratitude for the clarification that helped them finalize their understanding.
kiowaviator
This question is whooping me. I know I have the calculus part right I just don't know where to go from here?
A particle moving along the x-axis is acted upon by a single force F = F0e^(–kx), where F0 and k are constants. The particle is released from rest at x = 0. It will attain a maximum kinetic energy of
F0/k
F0/e^(k)
kF0
1/2(kF0)^2
ke^(k)F0
So using the Work Kinetic Energy theorem
W=Kf-Ki since x=0 then Kf=W
W=integral(F = F0e^(–kx),x,0,xf)
taking F0 out, since its a constant, and integrating the exponential function I get
W=F0[-e^(-kxf)/k + 1/k]
now what?
When you evaluate the integral one of the terms is zero,
exp(-x) goes to zero as x goes to infinity?
I did that, that's why the second term inside the brackets is 1/k, since e^(-k*0)=1.
You've pretty much done it now. So you now have 1/k inside the bracket and f0 outside the bracket, so just multiply them together to get the answer.
Ok, that makes sense. I was there I just couldn't see it. Thanks all.
