Maxwell and his equations essay - should i include aether theory heavily?
The essay on Maxwell's equations should focus primarily on his electrodynamic theory, demonstrating how it established light as an electromagnetic wave. Including aether theory is relevant, as it provides historical context, but the discussion should emphasize how experimental results, particularly the Michelson-Morley experiment, rendered aether theory obsolete. The essay can effectively conclude with the implications of relativity, which eliminated the need for aether. While there may be concerns about the relevance of aether theory, it can enrich the narrative of Maxwell's contributions to physics. Balancing the content will ensure a comprehensive and academically robust essay.
roberto85
Im writing an essay titled Maxwell and his equations. I want to talk about his electrodynamic theory and how his equations showed that light is an electromagnetic wave. I then want to include his involvement in aether theory since he had devised a theory to explain magnetism with an aether concept. But, the problem is I'm not sure if this seems like an obvious choice to discuss this concept since i would like to discuss the Michelson morely experiment and go on to talk about lorentz invaraince and how it was showed that aether theory's did not match experimental results.
The essay is 2000 words long and i want to spend half the essay on maxwells electrodynamic theory and the second half on maxwells aether theory but predominantly how the aether was shown to be unlikely to exist and then with the advent of relativity, how it became unneccesary. I do think it will be a nice way to conclude Maxwell's story since it has a firm conclusion but i also do feel like I am just indulging my own curiosity in aether theory and am worried that the markers might question the relavence of the aether theory portion of the essay.
Also, i feel a bit odd by concentrating on this aspect in an essay about Maxwell since his aether theory essentially became obsolete after M-M experiment. Ugh, i need opinions please!
I think you should include his theory and even his history in order for your essay to be presentable. And you don't know later on your essay will be consider as the most academic essay around the world!
I can't really say what you should or should not include. I'd say to actually make a essay plan of all the things you want to cover, and work out how to include all of those things. That way you won't run over the word limit, or devote too much of the essay to one part or another. :smile:
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
