ugenetic said:
I don't think your equation was correct. and I think curl of H outside of the wire SHOULD be zero. it should be I / Sqrt (x2 + y2) and x direction's expression should be -y/ sqrt(x2 + y2)
My suggestion was to assume a current distribution I(r) that is not concentrated on x=y=0, but spread around x=y=0.
Moreover, I suggest to assume any distribution of current I(r) (total current within radius r).
That leads to a magnetic field
H = I(r)/(2 ∏ r)
eΘ .
Replacing r as a function of (x,y,z) and taking the curl on Wolfram Alpha will help you understand what happens.
The clue is that with a continuous function I(r), the curl will give you the current density j = I'/(2πr) .
The reason why you got zero, is obviously because the derivation on Wolfram Alpha applies only on the domain of continuous functions. But you magnetic field is singular in x=y=0.
Have a check!
Simply paste this on Wolfram Alpha:
curl ( I(Sqrt(x^2+y^2)) (-y/(x^2+y^2), x/(x^2+y^2), 0) / (2 Pi) )
And analyze the result:
I'(sqrt(x^2+y^2)) / (2 pi sqrt(x^2+y^2)) e_z
I'(r) / (2 pi r)
You will recognize there the current density j.
Note also that, in the problem you wanted to solve, I'(r) is zero everywhere except in x=y=0.
If you already followed a course on the theory of distribution you could take for I a Gaussian distribution with a variable width w.
In the limit of w->0, you will verify that j=curl(H) will tend to the Dirac delta distribution.
