Mean of the square of a sum of exponential terms
grepecs
[/B]
Calculate \widehat{Y^{2}}
(i.e., the mean of the square of Y.
Y=\sum_{k=0}^{N-1}y_{k}
where
y_{k}=e^{-\gamma t}e^{\gamma \tau k}G_{k}
and
t=N\tau
The quantities y_{k} (or G_{k}) are statistically independent.
\widehat{Y^{2}}=\widehat{G^{2}}e^{-2\gamma t}\sum_{k=0}^{N-1}e^{2\gamma \tau k}=\widehat{G^{2}}e^{-2\gamma t}(\ \frac{1-e^{2\gamma t}}{1-e^{2\gamma \tau}} )
However, the correct answer should be
\widehat{Y^{2}}=\widehat{G^{2}}\frac{1}{2\gamma\tau} (\ 1-e^{-2\gamma \tau} )
so it seems like I'm doing something wrong, or is it possible to somehow simplify my answer in order to get the correct one?
grepecs said:
[/B]
where
and
t=N\tau
Unless the quantities ##G_k## have mean zero (##E G_k = 0##) and are identically distributed for different ##k## (or, at least, all have the same second moments), the expression you give is incorrect; and in that case the one given in the book (or wherever) is also incorrect. As far as I can see, the only way you could obtain something like the second expression would be to have non-zero values of ##E G_j G_k## of the form ##E G_j G_k = E(G^2) c_{jk}##, where ##E(G^2) \equiv E(G_1^2) = E(G_2^2) = \cdots = E(G_{N-1}^2)##. This is because we have ##Y = \sum_{k=1}^{N-1} w_k G_k## (with ##w_k = e^{-\gamma t} e^{\gamma \tau k}##), so that
Y^2 = \sum_{k=1}^{N-1} w_k^2 G_k^2 + 2 \sum_{1 \leq j < k \leq N-1} w_j w_k G_j G_k,
so you would need an appropriate value for the expectation of the second summation above, and that would depend on the form of the coefficients ##c_{jk}##.
Likes grepecs
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
