Measure the strength of the signal
Signal deterioration can be assessed by sending a known pulse through a lengthy cable and measuring the output with an oscilloscope to determine amplitude loss. The extent of signal loss is influenced by both the cable length and the frequency of the signal, with higher frequencies experiencing greater loss. For identifying issues like short circuits or open circuits in a bundle of wires, a cable tester may be necessary, as standard oscilloscopes may not effectively diagnose these problems. The discussion emphasizes the importance of understanding cable quality and signal integrity in a 24V system design. Practical observation of signal behavior using oscilloscopes is feasible and can aid in system design considerations.
Physicslearner500039
Hi all,
i have heard a lot of signal deterioration. so i just wanted to understand if i send a pulse let us say of some 5V and measure it using an oscilloscope and send it through a very lengthy cable and measure the same signal with an oscilloscope can i find that the amplitude of the signal coming down at some point of the cable? i also know that as the speed of the signal is increased the signal travels lesser distance. is it possible for me to practically observe these using our regular oscilloscopes? Based on these inputs i want to design a system where if lot of wires are bunched together is there is any short circuits within the wire? or any open circuits? quality of the wire? and other details is it possible? i am thinking of all these details for a 24V system.
Thanks in advance,
regards,
satya
Yes, give a known input signal and measure it out the output to determine the loss through the cable.
Another thing to keep in mind is that the signal loss is a function of the length of the cable AND frequency. Higher frequencies will have a greater loss.
As for the last part with the bunch of cables I am not sure what you are asking.
satya77 said:
Hi all,
Thanks in advance,
regards,
satya
From the last part of your question, it sounds like you are wanting something like a "Cable Tester":
http://www.google.com/products?q=cable+tester&hl=en
http://en.wikipedia.org/wiki/Cable_tester
Cable Testers can be used on transmission line type cable (twisted pair or coax), but would be less effective with cables that have unmatched wires in them...
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
