Measuring Spring Elongation in a Water-Filled Beaker
The discussion focuses on calculating the elongation of a spring connected to a block submerged in water. Participants clarify the use of Archimedes' Principle to determine the buoyant force acting on the block, which is equal to the weight of the water displaced. The correct buoyant force is calculated to be 67.3 N, while the weight of the block is 45.4 N. The net force equation is established, leading to a spring force of 21.9 N, which results in a final elongation of 0.14 m when applying Hooke's Law. Participants emphasize the importance of correctly accounting for all forces acting on the block to arrive at the accurate elongation value.
DDS
A light spring of constant k = 153 N/m rests vertically on the bottom of a large beaker of water (as seen in the picture below).
An m=4.63 kg block of wood (density = 675 kg/m3) is connected to the spring and the mass-spring system is allowed to come to static equilibrium (b).
What is the elongation, ΔL, of the spring?
I have tried this but it doesn't seem to give me the right answer:
L= (Volume of water - mass of block/ K) * 9.81
can anyone please give me some detailed help?
Are you familiar with Archimede's Principle? Use that to determine the weight of the block in the water and then use Hooke's Law to determine the deflection in the spring.
I am not. What is Archimede's Principle?
i have found his principle but how would i determine the amount of volume displaced?
i am using
w=D*V*g
The volume displaced is the volume of the block.
Specifically, you are looking for the buoyant force. It will be equal to the weight of the water displaced by the block.
what am i doing wrong here:
v=m/d
v=4.63/675
v=6.8959e-3
Fb=W=D*V*g
Fb=W=675*6.8959e-3*9.81
Fb=W=45.4203
now using Hookes Law:
F=-kx
-(45.4203/153)=x
x=-0.297 m
which is wrong any suggestions where i went wrong?
Your calculation for the buoyant force is incorrect. Think of it this way:
The block has a volume, that you already calculated, of V= 6.86x10^-3 m^3. How much does that same volume of water weigh? That is going to be:
F_b = (\rho_{water} )(V_{block})(g)
F_b = (1000 \frac{kg}{m^3})(6.86x10^-3 m^3)(9.81 \frac{m}{s^2})
F_b = 67.3 N
Now go back and use Hooke's Law to recalculate the deflection. I get .44 m for delta L.
hmm that's odd wen i put the asnwer in , it says its incorect
ive tired both positive and negative versions as well
any ideas where we went wrong?
ive gone over the calculations and they all seem correct...could it be a matter of units?
can anyone tell me where i went wrong??
I think you failed to include the weight of the block as a force acting downward. The net force on the block is the spring force plus weight (downward) plus buoyant force (upward).
So
w=mg
=4.63*9.81
=45.4
45.4+67.3 =112.7203
F=-(kx)
-(112/153)=x
x=0.736 m ??
is this correct because i only have one attempt left
DDS said:
So
x=0.736 m ??
No. Draw the forces acting on the block. Be careful with the directions.
okay the negative direction of that is it correct... because the fources acting on the block are:
Fb=up
Fsp=down
Fg=down
however i feel that the negative direction of that answer is incorrect
can anyone please verify
a verification or further suggestion would help because i have afeeling its wrong
Sorry. I fat-fingered my answer. I get a deflection of .14m, not .44m.
In my FBD, I have 3 forces acting: the buoyant force (Fb) acting in the positive direction, the weight of the block (W) acting in the negative direction and the spring force (Fs) acting in the negative direction.
F_B - W - F_s = 0
67.3 N - (4.63)(9.81) - F_s = 0
67.3 - 45.4 - F_s = 0
F_s = 21.9 N
F_s = k \Delta L
21.9 N = 153 \frac{N}{m} \Delta L
\Delta L = .14 m
Does that answer jive? Hopefully I haven't missed anything...
Thats what i had and was waiting for someone to verify , thanks so much
