Measuring the h conv from velocity not the same as that he gave
The discussion focuses on calculating the convective heat transfer coefficient (hconv) at -40°C with a wind speed of 0.5 m/s, using the formula hcov = 10.45 - v + 10√v. The initial calculation yielded a heat loss of 660 kcal/hr*m², but the user questioned the accuracy of the hconv value of 10. The conversation emphasizes that convective heat transfer coefficients are influenced by numerous variables, and the provided values are often approximations for educational purposes. The user ultimately recognized the utility of the hcov equation for varying velocities between 2 to 20 m/s in future calculations.
  • Understanding of convective heat transfer principles
  • Familiarity with the equation hcov = 10.45 - v + 10√v
  • Basic knowledge of thermal dynamics and heat loss calculations
  • Experience with temperature units and conversions
  • Study the impact of wind speed on convective heat transfer coefficients
  • Learn about the application of the hcov equation in real-world scenarios
  • Explore advanced topics in thermal dynamics, such as forced vs. natural convection
  • Investigate the effects of varying environmental conditions on heat loss calculations
Students and professionals in thermal engineering, HVAC specialists, and anyone involved in calculating heat loss in extreme conditions.
Manaf12
Determine the heat loss per square meter of skin surface due to convection at -40degreeC in moderate wind (0.5 m/s, Kc=10 Kcal/m2-hr-degreeC), assuming that the skin temperature is 26degreeC.
hcov= 10.45 - v + 10√v
ΔQ/Δt = A hconv (Tskin - Tair)
ΔQ/Δt/A= 10 x (26+40)
=660 kcal/hr*m^2
NOTE: i think it is wrong because when i measure hconv from the velocity =17≠10
Well, there are a couple of ways of looking at this. First, convective heat transfer coefficients are dependent on so many variables that in this complex situation you can't expect a simple calculation to be very good. His made up number is as likely to be right as yours. Second, made up problems often have made up numbers. You've undoubtedly calculated the acceleration of boxes sliding down ramps with completely made up coefficients of friction, and a hundred other similar examples. That didn't bother you then, why should this bother you now? Third, his number is in the ballpark and it is 10 which makes the calculation simple. Since he is just making this up and he can't say very accurately what the true number might be, give him credit for making a convenient choice. He could have made up a number with eighteen digits of precision. That wouldn't have illustrated the concept any better.
hey, thank you for the response, I found after a long period of searching that if the velocity between 2 to 20 m/s we can calculate the hconv from this hcov= 10.45 - v + 10√v
and from this question I found when I can use the equation above that will help in other questions , always simple questions helps
Thank you very much
  • · Replies 25 ·
