Mercury thermometer temperature problem
The discussion revolves around calculating the temperature corresponding to a 6.0 cm mercury column in a thermometer, given that it measures 5.0 cm at the triple point of water. Participants emphasize the importance of understanding linear expansion and the correct temperature for the triple point, clarifying that it is not 273 K. There is confusion regarding the terminology of steam versus water vapor, but the main focus remains on finding the appropriate formulas for the problem. Additionally, the lack of a specified radius for the thermometer's cylinder is noted as a potential issue in determining the height change of the mercury column. Overall, the thread seeks guidance on applying thermal physics concepts to solve the problem effectively.
robgb
The length of the mercury coloumn in a mercury thermometer is 5cm when the bulb is immersed in water at the triple point (273.16k). What is the temperature if it reads 6.0cm? What will the length of coloum be if immersed in boiling water (at steam point)?
I'm new to this forum, but would really appreciate any help you guys can give (need help asap!).
I've tried using pv = nKT etc, but can't apply it. All your hints would be welcome!
You want to examine the "linear expansion" formula. (since no dimension was given for "the bulb" I'm assuming that it's just one end of the colum and volumetric expansion is not necessary) You'll have to look up the coefficient of linear expansion for mercury.
edit: did the problem really say "triple point"? Nevermind, only the temperatures are important.
Hi,
Yes, in the question it didn't actually mention the temperature, just that it was the triple point.
Its supposed to be a pretty basic thermal physics question, any ideas what formula I would need to use?
Thanks, rob.
OK, the triple point is at a certain temperature, but it's not 273 K (that's the melting/freezing point). FInd that temperature and determine the "delta" T between each situation. Have you found the linear expansion formula yet?
Ok, thanks guys.
I'm still unsure as to where to go from here.
Any chance of a worked example anyone?
Please!
Thanks, rob.
The triple point of water has to be very near freezing. To get ice, liquid water and steam to exist in equilibrium
Wouldn't it be more accurate to speak of water vapour rather then steam?
Water vapour is liquid water in small droplets. Steam is the correct term for gaseous H2O.
By the way, I still don't see how you can calculate the change in height of the column if you don't now the radius of the cylinder.
