Calculating Stresses for Metal Pole Design in Audio System Installation
The discussion centers on the design and stress calculations for a metal pole intended to support horn speakers in a public audio system installation. The proposed structure consists of two poles, totaling 10 meters in height, with specific dimensions and a concrete base for stability. Concerns are raised about the pole's ability to withstand high wind speeds of 45 m/s while supporting a total weight of 80 kg from the speakers. The suggestion to modify the pole's height for cost reasons is met with caution, emphasizing the importance of professional engineering oversight. The thread concludes with a strong recommendation to seek local professional assistance to ensure public safety and compliance with regulations.
Shady Artin
I'm working on a public area audio system where we need to install our horn speakers on big height as per their installation requirements.
We designed a metal pole as described:
Pole consists of two poles: 1) a 7.5 meters height, 10" diameter, 6mm thickness. 1.5 meters are to be buried underground with concrete base, 2) a 4 meters height, 3" diameter, 5mm thickness. 1.5 meters are common with part1 pole and to be attached to it by two hinges with round metal "belts".
Final product should be of 10 meter height, 1.5 meter of them is underground, so it will be 8.5 meters above ground level.
On the top 2 meters of part2 pole, we should install 8 horn speakers on 4 levels (from top of pole: 50cm, 80cm, 110cm, 140cm) each horn weights around 10 Kg each (total of 80 Kg)
Final pole should withstand wind speed: 3 sec. gust speed, 45 m/s (160 km/h) at 10 m above ground
I need to know, how should I calculate the stresses to make sure that the pole will stand till under winds and also we are thinking about making the lower part 6 meters height instead of 7.5 meters and increase the difference in the upper part to be 5.5 meters instead of 4 meters for financial reasons, will that be acceptable??
Attached our initial design for more details.
Thanks in advance for your usual help
Thread closed for Moderation...
You seriously go to the Internet to try to get help with calculations like this that involve public safety? Don't you have professional engineers available to do this? Don't you have an insurance company that needs to sign off on the final design and construction? Don't you have city inspectors whose job it is to approve plans like these and do final inspections and sign-offs on the project?
Please get professional help locally, instead of putting the public at risk trying to cut corners on your construction projects getting advice off of the Internet.
Thread will remain closed.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
