Method to decide if calculating buckling failure is compulsory or not?
Determining whether to calculate buckling failure in columns can depend on specific criteria, such as the column's length and load conditions. A common approach is to perform a preliminary buckling calculation to assess the risk of failure. There are rules of thumb that suggest short columns may not require detailed buckling analysis. However, if the column is slender or subjected to significant loads, a thorough buckling evaluation is essential. Ultimately, conducting a buckling calculation is a straightforward method to ascertain the need for further analysis.
enotyphoon
Is there any method to define weather I have to calculate for determine buckling of column lead to fail or not. Is there is any rule of thumb or formula that show it is required to check for buckling or not (like very short column)
The simple calculation is to do a buckling calculation and see if the column will buckle...
Likes berkeman
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
