What dimensions minimize the surface area of a box with a fixed volume?
UMich1344
[SOLVED] Minimizing the Surface Area
A box has a bottom with one edge 8 times as long as the other. If the box has no top and the volume is fixed at V, what dimensions minimize the surface area?
V = lwh
SA (with no top) = lw + 2lh + 2wh
l = x
w = 8x
h = V/(8x^2)
Finding an equation for the surface area.
SA = lw + 2lh + 2wh
SA = x(8x) + 2x(V/(8x^2)) + 2(8x)(V/(8x^2))
SA = 8x^2 + V/(4x) + 2V/x
Finding the derivative of the equation in order to set it equal to zero to find the critical points, so the minimum can be found.
(d SA)/(d x) = 16x - V/(4x^2) - 2V/(x^2)
(d SA)/(d x) = (64x^3 - 9V) / (4x^2)
(d SA)/(d x) = 0
(64x^3 - 9V) / (4x^2) = 0
(64x^3 - 9V) = 0
64x^3 = 9V
x^3 = (9V)/64
x = ((9V)/64)^(1/3)
Plugging the solution into the equations for the dimensions.
l = x = ((9V)/64)^(1/3)
w = 8x = 8((9V)/64)^(1/3)
h = V/(8(((9V)/64)^(1/3))^2)
I am unsure if I did the right steps in order to find the solution.
Also, I am not very confident in the work I did for each step.
It looks good to me, except you can simplify 64^(1/3) into 4 so that you can reduce your answers and it looks cleaner.
Thanks a lot for looking over it. I just put it into the online grader and it is, in fact, correct.
I appreciate it.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
