Minimum and maximum uncertainty values in quantum harmonic oscillator
cleggy
I have to find the minimum and maximum values of the uncertainty of \Deltax and specify the times after t=0 when these uncertainties apply.
The wave function is Ψ(x, 0) = (1/√2) (ψ1(x)+ iψ3(x))
and for all t is Ψ(x, t) = (1/√2) (ψ1(x)exp(-3iwt/2+ iψ3(x)exp(-7iwt/2)
the expectation value <x> = 0 ( given in my text )
hence \Deltax= \sqrt{}&lt;x^2&gt;
using the sandwich integral
\int^{\infty}_{-\infty}ψ1\ast(x) x^2 ψ1(x) dx = \frac{3}{2} a^2
\int^{\infty}_{-\infty}\psi3\ast(x) x^2 \psi3(x) dx = \frac{7}{2}a^2
\int^{\infty}_{-\infty}\psi3\ast(x) x^2 \psi1 (x) dx = \int^{\infty}_{-\infty}\psi\ast1(x) x^2 \psi3 dx = \sqrt{\frac{3}{2}}a^2
where a is the length parameter of the oscillator.
Where do I go from here?
You have calculated the probability density function correctly in a previous question you asked. Where has the time dependence disappeared? Secondly how does one find minimum/maximum values of a function generally?
I don't know where the time dependence has gone
I'm not sure how to calculate the minimum and maximum values of a function?
I've been going at this for so long now my mind is turning mushy
If you're following a course on quantum mechanics I'm pretty sure you know how to find the minimum/maximum of a function.
Hint: derivative
so i have to do a first derivative test
First you need to find the correct time dependent expression for <x^2>. After that you take the derivative with respect to the appropriate variable and solve for said variable.
I don't know how to find the time dependent expression for <x^2>
In your other thread on this topic you calculated the probability density function for this time dependent wave function. The one with a sine in it and a t etc? You must remember.
This is the correct "sandwich" expression to use. What you've calculated now is the time independent expectation value of x^2.
cleggy said:
that should have been
|\Psi|^2 = [1/2][|\psi1|^2 + |\psi3|^2
+ 2\psi1\psi3sin(2wot)]
