Minimum seperation of two electrons moving toward each other
The discussion focuses on finding the minimum separation between two electrons moving toward each other. Participants are encouraged to use symbols exclusively to derive an algebraic expression for the minimum separation, denoted as ##r##. This approach helps avoid copying and rounding errors, ensuring accuracy in calculations. The thread was initially locked due to confusion between two users but has since been reopened for continued collaboration. The emphasis remains on developing a clear mathematical solution before substituting numerical values.
physicks885
Two electrons approach each other moving in opposite directions. When the separation between the electrons is 10 m, the two electrons move with the same speed of 𝑣=38 m/s. What is the minimum distance that the electrons will approach each other before they begin to move away due to the effect of electrical repulsion?
K.E = U
[Mentor Note -- Two threads started by partners in a class have been merged into this one thread, since they are working on a shared solution to turn in]
It looks like you have the correct idea. I strongly recommend that you redo the problem using symbols exclusively in order to find an algebraic expression for the minimum separation ##r##. Once you have that, you can substitute numbers at the very end. This eliminates copying and round-off errors and preserves your sanity.
Likes physicks885 and kareenlama
Locked pending moderation
  • Haha
Likes physicks885
Thread is now re-opened after sorting out the confusing two-user issue. :smile:
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
