What is the Most Effective Method for Minimum Stopping Distance in a Car?
To achieve the shortest stopping distance for a car on a horizontal road, the most effective method is to apply the brakes hard enough to just prevent slipping. This approach maximizes friction between the tires and the road, allowing for optimal deceleration. Simply locking the wheels can lead to a loss of control and increased stopping distance due to skidding. Pumping the brakes may also be less effective compared to maintaining optimal friction. Understanding the balance between brake force and tire traction is crucial for minimizing stopping distance.
ubergewehr273
In order to stop a car in shortest distance on a horizontal road, one should,
(a) Apply brakes very hard so that the wheels stop rotating
(b) Apply the brakes hard enough to just prevent slipping
(c) Pump the brakes (press and release)
(d) Shut the engine off and not apply brakes
NIL
I think the solution might be (a) because after the wheels stop rotating altogether, friction would stop the car entirely.
But I might as well be wrong.
Friction stops the car in all setups. But how fast does it stop? What is the force that stops it?
Well, there is no mention of it in the question...
Is this a question from the driving test?
Those are questions for you to answer.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
