Calculating Mixing Ratio of Hydroxyl Radicals at Sea Level
  • Thread starter Thread starter Nimmy
    Mixing Ratio
The typical global concentration of hydroxyl radicals (OH) is approximately 10^6 molecules/cm^3. To calculate the mixing ratio at sea level (P = 10^5 Pa, T = 298 K), the derived equations indicate that the mixing ratio is calculated using the formula N_{OH}/N_{total particles}. The calculations confirm that the mixing ratio is approximately 4.115*10^-14, with a note that unit conversion was a key consideration. Overall, the process outlined for determining the mixing ratio is correct, barring the initial unit conversion error.
Nimmy
A typical global concentration of hydroxii radicals (OH) is about 10^6 moleculues/cm^3. What is the mixing ratio corresponding to this concentration at sea level P = 10^5 Pa and T=298 K?
Using the previous equations derived earlier
ndOH= (P*Av/R*T)*COH
(ndOH*R*T/(P*Av) ) = COH
(10^6 molecules/cm^3)*(1 cm/100 m)*(1 cm/100 m)*(1 cm/100 m) = 1 molecule/m^3
((1 molecule/m^3 )*(8.314 J/mol*K)*(298 K)/(10^5 Pa)(6.022*10^23)) = COH
2477.572/6.022*10^23= 4.11*10^-21
Is this process correct? Thanks.
There are 100 cm per meter not the other way around.
Thanks but otherwise the correct process right?
PV= nRT = NkT
where N is number of particles, k is boltzman's constant, n is number of moles, and R is the gas constant.
C_{particles} = N/V = P/{kT}
mixing ratio = C_{OH}/C_{total particles} = N_{OH}/N_{total particles}
N_{OH}/N_{total particles} = {N_{OH}}/{{PV}/{kT}} = {10^6}/(({10^5}*{.01^3})/({1.381*10^{-23}}*{298}}) = 4.115*10^{-14}
You can keep doing it in moles if you want to but it just adds an extra step when you are being given the number of particles already. Looks like you did it right except for the unit conversion.
