Modification of Wheatstone Bridge
The discussion centers on calculating the total resistance of a modified Wheatstone Bridge when R2 is replaced with an ideal wire. Participants agree that R1 and R3 will be in parallel, forming R6, which is then in series with R4 to create R7. R7 is ultimately in parallel with R5. A key point of contention arises regarding the impact of replacing both R1 and R2 with ideal wires, leading to the conclusion that R3 becomes irrelevant, leaving R4 and R5 in parallel. The conversation concludes with appreciation for the clarification provided.
songoku
This is not homework, the question just crossed my mind when I was reviewing about Wheatstone bridge. Please see the picture below
Series and Parallel circuit
I want to ask what the total resistance of the circuit will be if R2 is removed and being replaced with ideal wire.
I think R1 and R3 will be parallel → let this be R6
R6 will be series with R4 → let this be R7
Then R7 will be parallel to R5
Is that correct? Thanks
Likes Delta2 and Charles Link
I also think you are correct.
Likes Charles Link
If both R1 and R2 are replaced by ideal wire, would I need to use Delta - star transformation?
Something like this:
where:
$$R_A=\frac{R_3 \times R_4}{R_3+R_4+R_5}$$
$$R_B=\frac{R_3 \times R_5}{R_3+R_4+R_5}$$
$$R_C=\frac{R_4 \times R_5}{R_3+R_4+R_5}$$
After that, ##R_A## will be parallel to ##R_B## and the result will be series with ##R_C##
No I don't think that's correct , if ##R_1## and ##R_2## are replaced by ideal wires then we shall have ##V_D=V_A=V_B## which means that effectively ##R_3## will also be out of the game. So you ll just have ##R_4## and ##R_5## in parallel. That's what I think.
Ah I see
Thank you very much for the help and explanation Charles Link and Delta2
Likes Charles Link
