Moment of inertia and Parallel axis theorem
soopo
1. Thehttp://nft01.nuk.edu.tw/lib/exam/97/master/97ap-master.pdf" statement, all variables and given/known data
A solid, uniform disk of mass M and radius R is oscillating about an axis through P. The axis is perpendicular to the plane of the disk. Suppose the friction at P can be ignored. The distance from P to the center, C, of the disk is b (see figure 1). The gravitational acceleration is g.
What is the moment of inertia for rotation about the axis through P?
I know the formula
L = Iw
Moment of inertia is I, while rotation per second is w.
The question asks to calculate the moment of inertia for rotation.
This seems to be apparently "L".
However, I am not sure, since this problem should be apparently solved with Parallel Axis theorem i.e.
I = I_{cm} + MR^2
where likely I_{cm} = .5 MR^2 is the moment of inertia though the center of mass.
However, I amn not sure, since this would imply
I = 1.5 MR^2How find the moment of inertia for rotation about the axis though P?
I know the formula
L = Iw
No. L is the angular momentum of the object when rotating at angular speed \omega.
I = I_{cm} + MR^2
I = 1.5 MR^2
You have found it. Why do you think it is wrong?
AM
AM
I did not know that the same Steiner's formula applies for moment of inertia of rotating objects.
There is no "w" in the Steiner's formula which made me to think that there is something wrong in the result.
Thank you for your answer!
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
