Moment of inertia of a suspended cylinder
A uniform cylinder suspended horizontally oscillates with a period of 2 seconds, while adding a 10 g disc to each end increases the period to 2.3 seconds. The moment of inertia of the cylinder is calculated using the angular velocities derived from the periods. The discussion highlights that conservation of angular momentum is not applicable due to the independence of the two scenarios. Instead, two equations involving the torsion constant and the moments of inertia are used to eliminate the torsion constant and solve for the cylinder's moment of inertia. Ultimately, the correct moment of inertia is determined through this method.
j_namtirach
A uniform cylinder 20 cm long, suspended by a steel wire attached to its mid-point so that its long axis is horizontal, is found to oscillate with a period of 2 seconds when the wire is twisted and released. When a small disc, of mass 10 g, is attached to each end the period is found to be 2.3 seconds. Calculate the moment of inertia of the cylinder about the axis of oscillation.
L = Iω
I = ∑(mr^2)
angular velocity of cylinder, ω = 2π/2 = 3.14 rad/s
angular velocity of cylinder with discs, ω = 2π/2.3 = 2.73 rad/s
Conservation of angular momentum:
Iω = Iω(1) + 2 (mr^2)ω(1)
3.14I = 2.73I + 2 x (0.01 x 0.1^2) x 2.73
0.41I = 5.46 x 10^-4
I = 1.33 x 10^-3 kg m^2
The correct answer is 6.2 x 10^-4, so I am way off. Any help would be much appreciated. Thanks!
Hey there. So, conserving momentum won't be of use here, since both situations are independent of one another. Instead, since this is a situation involving torsion pendulums, think of the equations relevant to those. The key one is
$$\omega^{2} = \frac{\kappa}{I}$$
Where ##\kappa## is the torsion constant of the wire. Since this isn't given, you can't use this equation to find the rotational inertia directly. Instead, if you have two equations, you can eliminate it to be able to find the inertia of the cylinder.
Thank you for the quick reply.
I'm still a little confused here. Is the mass of the discs not significant for this problem? I don't see how I can simply use the above equation to find the moment of inertia, since I don't know either the moment of inertia or the torsion constant. Sorry, I'm obviously not picking up on something here.
The idea is to create two equations to eliminate the torsion constant, since it's not given. So the first equation will use the period, torsion constant, and the moment of inertia of the cylinder, and the second one will use the other period, torsion constant, and the moment of inertia of the cylinder plus the inertia of the disks. Using both you can eliminate the torsion constant, and then solve for the moment of inertia of the cylinder since it will be the only unknown left.
Ok, thank, I got it:
for the cylinder: c = ω^2 I
for the cylinder + discs: c = ω(1)^2 I + ω(1)^2 (2(mr^2))
So: ω^2 I = ω(1)^2 I + ω(1)^2 (2(mr^2))
I got to the correct answer from here.
Thanks a lot for your help!
No problem! Glad you got it all worked out.
