How Do You Calculate Moment of Inertia for Connected Masses?
To calculate the moment of inertia for connected masses, the center of mass coordinates were found to be 0.057 m for both x and y axes. The moment of inertia formula, I = mA(rA^2) + mB(rB^2) + ..., was applied, but the initial attempt included incorrect distances for the masses. The first term for mass A was correctly identified as 0 m from the axis, while the distances for the other masses needed adjustment. Clarification was provided that the distances from the axis must accurately reflect the positions of each mass. Accurate calculations are essential for determining the correct moment of inertia.
Jaklynn429
http://i241.photobucket.com/albums/ff4/alg5045/p13-17.gif
The four masses shown in the figure below are connected by massless, rigid rods.
(a) Find the coordinates of the center of mass if MA = 130 g and MB = MC = MD = 260 g.
(b) Find the moment of inertia about an axis that passes through mass A and is perpendicular to the page.
I=mA(rA^2)+mB(rB^2)...
I got part A as being .057 m for both x and y.
now wouldn't i use:
(.130*0)+(.260*.05^2)+(.260*.0707^2)+(.260*.05^2)
?? Its telling me my answer is wrong?!
Hi Jaklynn429,
now wouldn't i use:
In the formula, r is the distance from each particle to the axis. The first term here is correct, because the 0.130kg particle is 0m from the axis. The other three terms seem to be saying that there are two 0.260kg particles that are 5cm from the axis, and one 0.26kg particle is is 7.07cm from the axis. Do you see what these last three terms need to be?
