Moment of Inertia: Solid vs Hollow Disk on Incline
A solid disk and a hollow disk of equal mass are compared in their descent down an incline. The moment of inertia plays a crucial role in determining which disk reaches the bottom first. The solid disk has a smaller moment of inertia because more of its mass is closer to the axis of rotation, while the hollow disk has a greater moment of inertia due to its mass being distributed further away. Consequently, the solid disk accelerates faster and will reach the bottom of the incline before the hollow disk. Understanding the relationship between mass distribution and moment of inertia is key to solving this problem.
Invictus1017
Alright, so say I have a solid wood disk, and a hollowed out disk of equal mass.
I roll them both down an incline, which one gets to the bottom first and why?
The scenario is very similar to this:
http://youtube.com/watch?v=7mxV6f5nuJY
I = MR ?
Something do with moment of inertia i think.
Thanks alot.
As you say, the moment of inertia is a crucial factor. You can answer this question quantitatively that is, explicitly calculate the moment of inertia for each disk and then evaluate it's acceleration. An alternative (and much easier) method would be to use the definition of Moment of Inertia for a point particle (I=mr2 not I=mr as you have above), and logical reasoning.
So to start we know that both their masses are equal, using the definition of I that I gave you above, can you make the next step?
I'm not sure but, the radius from the center of mass to the axis of the hollow disk is larger than the radius of the solid disk? Resulting in a smaller moment of inertia for the solid disk?
Well you conclusion is correct, but your reasoning is wrong. The centre of mass of both disc both lie on the axis of rotation. However, the hollow disc has a greater proportion of its mass located further away from the axis of rotation, thus the moment of inertia is greater. Does that make sense?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
