Momentum states normalization
In summary: What is the value of <p|p> when a_k^+|0>=sqrt(2E_p)|0>?... in the technical QFT forum.Member u_p is not only important for QFT, but for any "true" quantum theory. The question about normalization is a general one.
physichu
30
What is the value of ##\left\langle {{\bf{p}}|{\bf{p}}} \right\rangle ## when ##a_{\bf{k}}^ + k\left| 0 \right\rangle = \sqrt {2{E_{\bf{p}}}} \left| 0 \right\rangle ##? (like in Peskin)
I suppose that ##\left\langle {\bf{k}} \right|{a_{\bf{k}}}{\bf{P}}a_{\bf{k}}^ + \left| {\bf{k}} \right\rangle = {\bf{k}}##.
So
##\eqalign{
& \int {{{{d^3}p} \over {{{\left( {2\pi } \right)}^3}}}{\bf{p}}\left\langle 0 \right|{a_{\bf{k}}}a_{\bf{p}}^ + a_{\bf{p}}^{}a_{\bf{k}}^ + \left| 0 \right\rangle } = \int {{{{d^3}p} \over {{{\left( {2\pi } \right)}^3}}}{\bf{p}}\left\langle 0 \right|{a_{\bf{k}}}a_{\bf{p}}^ + \left\{ {\left[ {a_{\bf{p}}^{},a_{\bf{k}}^ + } \right] + \overbrace {a_{\bf{k}}^ + a_{\bf{p}}^{}}^{ = 0}} \right\}\left| 0 \right\rangle } = \cr
& = \int {{d^3}p{\bf{p}}\left\langle 0 \right|{a_{\bf{k}}}a_{\bf{p}}^ + \left| 0 \right\rangle \delta \left( {{\bf{k}} - {\bf{p}}} \right)} = {\bf{k}}\left\langle 0 \right|{a_{\bf{k}}}a_{\bf{k}}^ + \left| 0 \right\rangle = {\bf{k}} \cr} ##.
This implies ##\left\langle 0 \right|{a_{\bf{k}}}a_{\bf{k}}^ + \left| 0 \right\rangle = 1##
and
##\left\langle {{\bf{p}}|{\bf{p}}} \right\rangle = {1 \over {2{E_{\bf{p}}}}}##
am I right?
No you are wrong. Try using the |k> I write below to calculate <q|k> and then see what happens for q=k.
I think you did a typo, because in Peskin it is:
[itex] |k> = \sqrt{2E_k} a^\dagger_k |0> [/itex]
So try working on [itex]<q|k>=?[/itex]Also I'd like you to justify your "suppose that [itex]<k| a_k P a_k^\dagger |k> =k [/itex] " .
In Peskin; page 22 just under equation (2.23) it says "So the operator ##a_{\bf{k}}^ + ## creates momentum ##{\bf{p}}## ..."
and becuse ##{\bf{P}}## meusure momentum i thout that:
##\left\langle 0 \right|{a_{\bf{k}}}{\bf{P}}a_{\bf{k}}^ + \left| 0 \right\rangle = {\bf{k}}##.
Now, Peskin say ##\left\langle {{\bf{p}}|{\bf{q}}} \right\rangle = 2{E_{\bf{p}}}{\left( {2\pi } \right)^3}{\delta ^{\left( 3 \right)}}\left( {{\bf{p}} - {\bf{k}}} \right)##
but how do you interpret ##\left\langle {{\bf{p}}|{\bf{p}}} \right\rangle = 2{E_{\bf{p}}}{\left( {2\pi } \right)^3}{\delta ^{\left( 3 \right)}}\left( 0 \right)##?
Well you can work this out and get the <p|q> ...
As for the momentum, I am not sure... shouldn't the a-operators bring you some energy factor? Maybe I'm wrong...
You have to keep in mind that [itex] \delta^3 (p -p ) [/itex] represents the volume of the space. What do you know about plane wave states from QM?
Acording to the interpretation that the delta functio is the volume of space we get ##\left\langle {{\bf{p}}|{\bf{p}}} \right\rangle = \infty ##,
which mean that ##\left| {\bf{p}} \right\rangle ## is un-normelizable and thuse not representing anything real.
For a plane wave that's normal, since the plane wave is extended in all space..
If on the other hand you choose a wavepucket state [itex]|f> =\int \frac{d^3p}{(2 \pi)^3} \frac{f(p)}{2E_p} |p>[/itex] then the formula for [itex]<f|f>[/itex] will not vanish.
Likes physichu
Why dose a wave spread on all space has infinite momentum? and how do you know it's extended in all space?
besides, it's not what Peskin says:
page 22 just under equation (2.23) it says "So the operator ##a_{\bf{p}}^ + ## creates momentum ##{\bf{p}}## ..."
It does not have infinite momentum. The infinity you get is the problem to normalize the corresponding wave function.
A wave function that spreads on all space is in all space by definition. I don't understand that question.
So how do you normalize it?
You don't, it is not a physical state.
Likes physichu
physichu said:
page 22 just under equation (2.23) it says "So the operator a+pa_{\bf{p}}^ + creates momentum p{\bf{p}} ..."
Where was that referring to?
A plane wave can have definite momentum (if you like to see it from HUP, the fact that the plane wave has definite momentum means that its position is completely uncertain and so it extends in the whole space)...
Let's put that in a different way, from QM: are plane waves normalizable?
Well, I guess, if answered in this style, we should push the whole thread to the homework section ;-).
A little tip: First think in terms of "first quantization" in non-relativistic quantum theory. The momentum "eigenstates" in position representation are plane waves
$$u_{\vec{p}}(\vec{x})=N \exp(\mathrm{i} \vec{x} \cdot \vec{p}),$$
where ##N## is an arbitrary normalization constant. The scalar product is given by
$$\langle \psi_1|\psi_2 \rangle=\int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x} \psi_1^*(\vec{x}) \psi_2(\vec{x}).$$
Now try to answer ChrisVer's questions, particularly whether you can calculate the norm of the momentum eigenfunction. Then try to evaluate
$$\langle u_{\vec{p}_1}|u_{\vec{p}_2} \rangle.$$
This should help to understand, what's going on here.
For a pragmatic but better introduction than usually found in QM textbooks, see
L. Ballentine, Quantum Mechanics, A Modern Development, Addison Wesley
Sorry (from you? and from the one who posted the OP) for my style, I chose for once to try and put someone do the calculation by himself and figure it out...When it came to explaining things I guess I and mfb gave a normal "answer". I mean it ends up being a QM question from a QFT one.
To help the OP though understand how the [itex]u_p[/itex] is associated with [itex]|p>[/itex] it's exactly the fact that they are the same thing. Both are the eigenstates of a given momentum [itex]p[/itex]. The [itex]u_p(x)[/itex] vanhees wrote is [itex]<x|p>[/itex] and that's how the integral [itex]\int d^3x[/itex] appears when taking their inner product (by the insertion of unity [itex]I= \int d^3 x |x><x|[/itex] between the inner product ).
Likes vanhees71
It was not meant as a criticism, because indeed, to figure this out once oneself, is crucial for an understanding of the continuous spectra of operators in quantum theory. For that reason, I think the thread is better moved to the homework section, because there it might get more attention than here.
The problem is that it is not a homework assigment.
Let me see if i got it right:
from
answer to my question
i understand that ##a_{\bf{k}}^ + \left| 0 \right\rangle ## is not a physical state,
so it is O.K. that ##\left\langle 0 \right|{a_{\bf{k}}}a_{\bf{k}}^+ \left| 0 \right\rangle ## have no meaning.
Is it right to say that ##\left\langle {{\bf{p}}|{\bf{q}}} \right\rangle = 2{E_{\bf{p}}}{\left( {2\pi } \right)^3}{\delta ^{\left( 3 \right)}}\left( {{\bf{p}} - {\bf{q}}} \right)## have no physical meaning either and it's just an instrument for calculation?
Now, i had a mistake in the first post, i wrote ##\left\langle {\bf{p}} \right|{a_{\bf{k}}}{\bf{P}}a_{\bf{k}}^+ \left| {\bf{p}} \right\rangle ## instead of ##\left\langle 0 \right|{a_{\bf{k}}}{\bf{P}}a_{\bf{k}}^+ \left| 0 \right\rangle ##.
setting this straight, the question still remain:
dose ##\left\langle 0 \right|{a_{\bf{k}}}{\bf{P}}a_{\bf{k}}^+ \left| 0 \right\rangle ## have a meaning and if so, is it true that ##\left\langle 0 \right|{a_{\bf{k}}}{\bf{P}}a_{\bf{k}}^+ \left| 0 \right\rangle = {\bf{k}}##?
Great! Now you got the correct relation,
$$\left\langle {{\bf{p}}|{\bf{q}}} \right\rangle = 2{E_{\bf{p}}}{\left( {2\pi } \right)^3}{\delta ^{\left( 3 \right)}}\left( {{\bf{p}} - {\bf{q}}} \right),$$
where the prefactor is conventional. It's the usual (modern) choice in HEP, because it leads to the definition of S-matrix elements that are manifestly Lorentz covariant. Have a look in the section on the definition of the invariant cross section in Peskin and Schroeder, because there it's very well described in which sense, the here discussed "momentum eigenstates" have a physical sense.
To answer your final question, now think first, what is
$${\bf P} a^{\dagger}_{{\bf k}} |0 \rangle,$$
and then think about, wheter it makes sense to multiply this from the left with ##\langle {\bf k}|##!
Likes physichu
O. K. I THINK I GOT IT!
Following Peskin equation (4.65)
##\left| \phi \right\rangle = \int {{{{d^3}k} \over {{{\left( {2\pi } \right)}^3}}}{1 \over {\sqrt {2{E_{\bf{k}}}} }}\phi \left( {\bf{k}} \right)\left| {\bf{k}} \right\rangle } = \int {{{{d^3}k} \over {{{\left( {2\pi } \right)}^3}}}\phi \left( {\bf{k}} \right)a_{\bf{k}}^ + \left| 0 \right\rangle } ##
taking ##\phi \left( {\bf{k}} \right) = \exp \{ - {{\left| {{{\bf{k}}^2} - {{\bf{p}}^2}} \right|} \over a}\} /b##
and b such that
##\int {{{{d^3}k} \over {{{\left( {2\pi } \right)}^3}}}{{\left| {\phi \left( {\bf{k}} \right)} \right|}^2} = 1} ##
we finally have:
##\eqalign{
& \left\langle {\phi |{\bf{P}}|\phi } \right\rangle = \int {{{{d^3}p{d^3}k{d^3}k'} \over {{{\left( {2\pi } \right)}^9}}}} {\bf{p}}\phi \left( {\bf{k}} \right)\phi \left( {{\bf{k'}}} \right)\left\langle {0|{a_{\bf{k}}}a_{\bf{p}}^ + {a_{\bf{p}}}a_{{\bf{k'}}}^ + |0} \right\rangle = \cr
& = \int {{{{d^3}k{d^3}k'} \over {{{\left( {2\pi } \right)}^6}}}} {\bf{k'}}\phi \left( {\bf{k}} \right)\phi \left( {{\bf{k'}}} \right)\left\langle {0|{a_{\bf{k}}}a_{{\bf{k'}}}^ + |0} \right\rangle = \cr
& = \int {{{{d^3}k} \over {{{\left( {2\pi } \right)}^3}}}} {\bf{k}}{\left| {\phi \left( {\bf{k}} \right)} \right|^2} = {\bf{k}} \cr} ##.
So ##\left| \phi \right\rangle ## is a realistic eigenstate of ##{\bf{P}}## and ##{\left| {\bf{k}} \right\rangle }## is just a mathematical tool.
right?
But...
Isn't ##\mathop {\lim }\limits_{a \to \infty } \exp \{ - {{\left| {{{\bf{k}}^2} - {{\bf{p}}^2}} \right|} \over a}\} /b = \delta \left( {\bf{p}} \right)##
so
##\eqalign{
& \mathop {\lim }\limits_{a \to \infty } \left| \phi \right\rangle = {1 \over {\sqrt {{{\left( {2\pi } \right)}^3}2{E_{\bf{p}}}} }}\left| {\bf{p}} \right\rangle \cr
& \cr
& \left\langle {\phi |\phi } \right\rangle = 1 \cr
& \Downarrow \cr
& \mathop {\lim }\limits_{a \to \infty } \left\langle {\phi |\phi } \right\rangle = {1 \over {{{\left( {2\pi } \right)}^3}2{E_{\bf{p}}}}}\left\langle {{\bf{p}}|{\bf{p}}} \right\rangle = 1 \cr
& \Downarrow \cr
& \left\langle {{\bf{p}}|{\bf{p}}} \right\rangle = 2{E_{\bf{p}}}{\left( {2\pi } \right)^3} \cr
& \Downarrow \cr
& \left\langle {0|{a_{\bf{p}}}a_{\bf{p}}^ + |0} \right\rangle = {\left( {2\pi } \right)^3} \cr
& \cr
& \delta \left( {{\bf{p}} - {\bf{p}}} \right) = 1 \cr
& \cr
& H = \int {{{{d^3}p} \over {{{\left( {2\pi } \right)}^3}}}{\omega _{\bf{p}}}\left( {a_{\bf{p}}^ + {a_{\bf{p}}} + {1 \over 2}\left[ {{a_{\bf{p}}},a_{\bf{p}}^ + } \right]} \right)} \cr
& \cr
& H = \int {{{{d^3}p} \over {{{\left( {2\pi } \right)}^3}}}{\omega _{\bf{p}}}a_{\bf{p}}^ + {a_{\bf{p}}} + } {1 \over 2}\int {{d^3}p{\omega _{\bf{p}}}} \cr} ##.
We can define ##\delta \left( {{\bf{p}} - {\bf{p}}} \right) = 1## which will extend the kroneker delta.
Now ##H = \int {{{{d^3}p} \over {{{\left( {2\pi } \right)}^3}}}{\omega _{\bf{p}}}\left( {a_{\bf{p}}^ + {a_{\bf{p}}} + {1 \over 2}\left[ {{a_{\bf{p}}},a_{\bf{p}}^ + } \right]} \right)} ## (Peskin e. (2.31)
will be ##H = \int {{{{d^3}p} \over {{{\left( {2\pi } \right)}^3}}}{\omega _{\bf{p}}}a_{\bf{p}}^ + {a_{\bf{p}}} + } {1 \over 2}\int {{d^3}p{\omega _{\bf{p}}}} ## which is still infinity.
and ##\left\langle {0|a_{\bf{p}}^ + {a_{\bf{p}}}|0} \right\rangle = \left\langle {0|\left[ {a_{\bf{p}}^ + ,{a_{\bf{p}}}} \right] + {a_{\bf{p}}}a_{\bf{p}}^ + |0} \right\rangle = - {\left( {2\pi } \right)^3} + {\left( {2\pi } \right)^3} = 0##
so everything works fine.
(I played a little with the ##{2\pi }## so it will fit)
Point 1: your delta function definition, as a limit of the exponential is wrong in form. The delta function should have the limit going to 0, and not of that expression I think.
Is it logical to say [itex]\delta(0)=1[/itex]?
Also for [itex]<0|a_p^\dagger a_p |0> =0[/itex] you can see that immediately for you are taking the "average" number of quanta in the vacuum (which is zero).
##\eqalign{
right?
You must be a bit more careful! Just plug in your wave packet from Peskin-Schroeder step by step into your expectation value. Finally you should get, of course,
\begin{equation}
\langle \vec{p} \rangle =\langle \phi|\vec{\bf P} \phi \rangle=\cdots=\int_{\mathbb{R}^3} \frac{\mathrm{d}^3 \vec{p}}{(2 \pi)^3} \vec{p} |\phi(p)|^2,
\end{equation}
because ##|\phi(p)|^2/(2 \pi)^3## is the probability density for measuring a momentum ##\vec{p}##. So your final result is correct, but the steps in between are not consistent with the definitions used before!
1. What is momentum states normalization?
Momentum states normalization is a mathematical concept used in quantum mechanics to describe the probability of finding a particle with a given momentum. It involves normalizing the wave function, which represents the probability amplitude of the particle, to ensure that the total probability of finding the particle in any state is equal to 1.
2. Why is momentum states normalization important?
Normalization of momentum states is important because it ensures that the probability of finding a particle in any state is physically meaningful. Without normalization, the probability could be greater than 1, which is not physically possible.
3. How is momentum states normalization calculated?
Momentum states normalization is calculated by taking the square root of the integral of the wave function squared over all possible momentum states. This ensures that the total probability of finding the particle in any state is equal to 1.
4. What is the significance of momentum states normalization in quantum mechanics?
In quantum mechanics, the wave function represents the probability of finding a particle in a particular state. Normalizing the wave function, including momentum states, allows for accurate predictions of the behavior of particles on a quantum level.
5. Are there any exceptions to momentum states normalization?
There are certain situations where momentum states normalization may not be necessary, such as when dealing with infinite potential wells or delta function potentials. In these cases, normalization may not be possible or may not accurately represent the physical system.
  • Quantum Physics
  • Quantum Physics
